I've had a search around in the forum and on google and can't seem to find a great deal.
I've got a 32 GTR with a twin Kakimoto system on. I hate the twin cannon rears and it's a touch on the loud side. So I'm going to change the twin 70mm to a single 100mm before the rear muffler and fit a single oval 100mm muffler.
Basically I've spoke to a few muffler shops who said they couldn't get hold of a stainless one. I've done some searching myself and spoke to Xforce, they do one, but I can get a Borla or a Magnaflow for similar money from the states.
I'm a Pom and haven't heard of Xforce as we don't really get then over there. I'm just making sure they're not cheap crap because if they are I'll go for the magnaflow/Borla option
Cheers
Chris
https://www.sau.com.au/forums/topic/433698-xforce-mufflers/
I changed my 4 inch catback to a 3 inch catback with an x force mid and rear muffler. 4 inch was overkill and the sound was ridiculous.
I also have a 3inch turbo to cat. (HKS off the shelf whatever)
The muffler shop said it would be much more restrictive however I made the exact same power. I was expecting to lose some boost in the top end and maybe some response, but nah its the same shit.
so +1 for xforce from me
https://www.sau.com.au/forums/topic/433698-xforce-mufflers/#findComment-7072232
There is very little difference in any of the straight through muffler designs from my experience. It's just a perforated pipe with packing at the end of the day. Go as large as you can with the muffler body to reduce decibels, and don't go larger than you need to in pipe size.
  • Like 1
https://www.sau.com.au/forums/topic/433698-xforce-mufflers/#findComment-7073127
I was running a 3 1/2inch system with a 3inch Xforce oval muffler, before that I had a 4inch nurspec ( bloody noisy), fujitsubo( quiet but 2inch restrictor) and I found the Xforce muffler great for flow and noise was perfect.
https://www.sau.com.au/forums/topic/433698-xforce-mufflers/#findComment-7073586
I bought second hand, and got a mild steal 3" bell-mouth dump for $60 and a stainless 3" cat-back with a large oval mid, and at the diif it ups to 3-1/2" with a short cannon for $200.
Then I bought a new catco 3" flanged cat for $175 off KMS
= brilliant quiet system for a grand sum or $435...
at least look at S/H options before you spend thousands
https://www.sau.com.au/forums/topic/433698-xforce-mufflers/#findComment-7074292
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
