Thanks for the info SK
I'm just waiting for to get the 044 now and then ill be following what you said to externaly mount it.
Only thing is.. while you are taking photos of the internal set up could you also take a snap of the join that you were saying about.
Thanks mate
Hey SK -
I have been thinking about my upgrade power path.. and was wondering if I will need bigger injectors?
I read in another thread that you were sayind that you have been able to get 420cc's out of the stock r33 injectors just with the GTR fuel pump. How would this with a 044 and a pressure regulator go? Will this be enough for my wanted 300 - 350 rwkw? I'm thinking no but I don't know (hence the question)
What I was looking at was the rx7 550cc side feed injectors.. If I did need bigger injectors would these be good enough?
Sorry to pick your brain again mate.
Thanks
Hey SK -
Thanks
Hi riceline, easy answer...
350 rwkw = 470 rwhp
470 rwhp + 80 bhp (losses) = 550 bhp
In a 6 cylinder injector cc's = bhp
so 420 cc's = 420 bhp
Obviously the 550 cc injectors are a much better choice for 350 rwkw.
Hope that helped :D
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
