hi,
just finished putting my car back toghether over the w,e i had the 4wd fuse pulled before hand, so once car was running i re installed fuse, but the 4wd light hasnt gone off, nor is the torque gauge working? but its defently back to 4wd, help? lol
also now aswell my temp gauge is fine until i put the clutch in and release handbrake then it goes of the scale, but seems to go up and down with accelerator, and bumps in the road, ive got absoluley no idea whats going on.
any help would be appreciated.
https://www.sau.com.au/forums/topic/433729-32-gtr-gauge-issue/
Mate - I've read about 5 posts of yours so far.
Did you even check this GTR out before buying it ?
If you knew it had issues and you don't know what your doing then take it into a trustworthy shop.
or USE THE SEARCH FUNCTION !!
1. Make certain all your earthing is good first
2. Grab another cluster and put it in.
3. Did you do any wiring - how does the clutch make the temp gage go off the dial.
Edited by Sinista32
geee cheers, YES i had the god damn car at a trustworthy highly known sydney shop, but i cant justify $150 an hour for labour, and prefer to do things myself if possible.
sorry if my car and posts bother you, but i thought this is a forum? and you ask questions on here. ffs!
There's 2 fuses for 4wd (in cabin and under bonnet).
Leave the car off when checking and re-installing the fuse/s.
Pull the cluster out and make sure the three plugs are well connected when you put it back in.
On the film there is wiring that leads into where the plugs are inserted. Check they are pushed out so that when the plugs go in they make good connection
Underneath your centre console is the G'' sensor. Make sure it is not - red - in the glass area on the side.
Make certain plugs are connected in tightly.
Again make certain all earths are clean and connected.
Temp sensor and clutch does not make sense. Maybe loose wiring when clutch engaged.
After all that if you still have problems look for a 2nd hand cluster
Edited by Sinista32
I'm thinking its a pinched wire in main harness behind engine that maybe contacts metal somewhere depending on movement of engine, if it were me id pull that wire out back to firewall and run new one to temp sensor or at least check it with multi meter or grab wires and wiggle them with ignition on and someone watching gauge should be able to find it pretty easy as clearly the clutch has no real effect on engine temp failing that it must be cluster
like sinista32 said check your G sensor I'd also go to the trouble of cleaning all your electrical connectors check earthing etc. My 32 temp gauge would go up and down over large bumps got it checked over and tested seemed to be ok. Let us know how you go trying to sort it out
  • Like 1
well thanks guys for the usefull info it helps, im in the process of going over just about every wire and harness throughout the car.
ive found dodgey connections on the temp sender wires so maybe thats all it its, but me being abit of a perfectionist, im going over everyting, soldiering connections where i can re wrapping wires in heatshrink etc,
yeah i dont understand the whole clutch making the guage move but strange things happen i supoose.
g sensor isnt red which is a positive,
quick question, the 2 wires going to the temp sensor, yellow with a green line, and a black wire, they both have silver dots every 50mm along the wires, do i need to find the same wires to replace the ends? need to cut off damaged bits and join on some new stuff or it will be to short, will any old wire the same colour and size work? just the silver dots are throwing me off abit.
and to make things worse the under dash area and behind centre intrument console, are an absolute birds nest, so many dodgey joins in wires,cut and tucks every where, i found an old nokia box thing with like phone cord plugs plugged in,another alpine box ipod connector adapter with similar plugs, geeeeeesssuuuuuuuss. an auto electrician would loose there mind if they seen the wiring mess i have, ohh well lucky i love my gtr. :yes:
hehehe
Can't help you with the wiring and what to use to replace it :( - but I'm sure someone on here can.
When I had the dash replaced in my GTR the shop removed a good size box of extra wiring and gizmo's ^ no longer in use
Like you have found all sorts of gear had been installed/removed and/or just left laying around back there.
  • Like 1
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
