I'm assuming this is for your R34 GTT?
If so, what kind of work do you want done by them?
There's lots of shops I'd recommend for oil changes etc, but wouldn't let them come within 50 meters of the car if it was a turbo upgrade or head rebuild...
Keep in mind also, that every shop is going to have good and bad stories... Generally go with a workshop that's been around for a while, noone stays in business long if they don't know what they're doing and just generate constant bad rep...
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074020
Yeah I understand people are going to have good/bad, if the good out weighs the bad I may try them if there are no "horror" stories.
if someone compared them to OH Performance that used to be in Sunshine I'd steer well clear...
What are you looking to get done?
Looking for someone that can do everything or as much as possible.
I need a hi-flow cat and a new boost controller to start with, then I'll be looking at flex fuel and a retune to suit.
I've been to chasers (west) to get a knock from the previous owner fixed, came out just as bad... good waste of money that was. So then I tried RE Customs, they fixed the knock so I've been going there for services and got them to install an aftermarket turbo. No complaints about the work except its just too far. Takes me an hour and a half to two hours to get there in "light" traffic.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074077
Basic mechanical work like hi-flow cat's and a new boost controller installation can be done by nearly anyone... If you've got an aftermarket ECU though, it is WORTH spending the time travelling a little bit to go to a good tuner! Should only really need to be done only once or twice per year IF you keep modding throughout the year and plan out when it is going to need a new touch-up tiune.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074122
I know thanks. I'd get it all done at once instead of getting 5 tunes obviously.
Somewhere decent in the western suburbs would be nice though, whether a big or small job, as I said I'd prefer to take it to the same place so they know the car and what they've done.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7074146
Edge is a great workshop, but they send a lot of their bigger welding jobs to me, not sure they have a permanent fabricator there at the moment.
I second this... chasers left a bad taste in my mouth. Edge motorworks will be under going some serious work on my r34 gtt sedan and shall be making well into the 300++ rwks by next week. They are professional, prompt and clean n chian is a wicked tuner
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7076482
Hope to see it there Rob, my Yellow evo is there for a stroker build. :)
Love Cihan's tuning and the way he explains any issues he's having with the car, I always leave happy... Well other than that one time I lifted the head during a run. :P
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7076521
I also know Barry and Kennan, ive known Kennan since he was a little kid riding his bike in my area.
Kennan breathes, eats and shits Nissans, when i take my stuff to Barry its only he and Kennan that i trust.
Barry is old school, very honest and down the line, ive watched him work carefully and he does things how i would have done them myself.
Thats why when im busy or there is no room in the garage to work, we send them our own cars.
Also their Dyno guy, Ghian is really good at what he does, one particular car from Sydney was sent to them, a Supra with the plates Gameon produced some really good figures....run in tune was 31psi, 7500 redline making 750Kw at the rears....i wont get into what it made on 3 bar......
They will be installing. running in and tuning our RB26/30 when the time comes.
I also noted a lot of RB28 strokers in his engine room being built right now between the 2JZ's.
https://www.sau.com.au/forums/topic/433767-edge-motorworks/#findComment-7095730
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
