Met Barry while getting tune done by Chian. Barry was nice to speak to and Chian's tune is absolutely awesome and this was 3 years ago. Been to a few big names for tunes but in my book Chian's tune is much better than any other I've had.
Imagine someone after reading this thread then walks into Edge and asking to speak to master Rajab.... LOL
Will use that one on Barry next time he calls.
He is use to hearing me answer his incoming calls with a "You Farkin Bosnian Carnt trouble makers...."
If you really want to upset him say your getting a engine built or advice from "the King of SR20's", he knows who it refers too and really get up his nose.
Then tell him Peter told you to say it before he punches you. :)
Edited by GTRPSI
    • Haha watch Alex's eye twitch when you mention Nistune to him in person lol. He's not a fan, then again it's quite a niche product. I personally don't mind them, but most usually steer clear from it. Word of advice, do not ground the AFM to the chassis, there are heaps of incorrect guides on the interwebs. Send both GND on the AFM back to Sensor GND on the harness.
    • Note I edited my post, so Sleeper's quote is not the same as what I meant any more.
    • That's a whole 'nother issue. Nissan ones get dirty and sticky. The coolant heats the wax pellet thingo to close the valve, so it is open when it is cold. And so if there is no coolant it just takes longer to close, because the heat has to soak all the through the inlet manifold.
    • I feel like this is crazy pills though. Isn't it locked up all the time anyway? It shouldn't flare anywhere if it only unlocks momentarily while it shifts gears. And if it flares like that when shifting gears, then the 8HP with a 5500 stall is not driving as well when on the road and/or track use..
