Antilag Racewars 2014 - 12Th & 13Th April, Wyalkatchem Airport
Antilag RaceWars 2014 dates have been released today, it will be held on the 12th and 13th of April once again at Wyalkatchem Airport.
Last year was ridiculously fun and I can't wait to wind some boost up, drop some kilos and better last years efforts.
Anyone else planning on going?
http://www.racewars.com.au/
More power is definitely required, seems I've got some quick cars chasing my title.
650 - 700 Sarah Jessica Parkers should do the trick I think ;)
will be entering
shooting for 650 - 700 whp for the event
hoping the 6 speed gives me a bit more pull in the top end
just booked my accommodation tonight, get on it lads isnt much close by around.
True that, I'm staying at the Dowerin Hotel ~20mins out of Wylie.
haha thats where i booked, ZZM5 has also booked at dowerin Hotel.
however am hunting down a house within close proximity of the track, so if we get house will just onsell the dowerin hotel rooms.
Hi, folks.
I enjoyed myself this year and have a point to prove next year! I have booked my accommodation in Dowerin just now. I hope it is not quite as hot and they iron out the kinks in the schedule. The organisers did a great effort for the first year.
Still learning to drive, it would appear!!!
:blink:
whats the point you wish to prove?
More to myself, than anything else. For lots of reasons, I stuffed up and ran in low boost all through the Saturday. Then on the Sunday I only managed two runs on the 1000 metres, because I was flying out that night and had to get back. The first one, the timing didn't work and I had a good indicated top speed. The second one, I stuffed the start and one gear change and the timing worked. So, I came away with the overall feeling that I had not driven the car to its potential. I want to do that this time.
So that is the point I want to prove to myself.
LOL I no own a 31 , 34 is just about finished :)
Weak :P
I only had the one run at 1,000m myself, I certainly had an average start and a short shift, could have gone faster but doubt I could have pulled up in time, haha!
Edited by Hank Scorpio
1000m = need good brakes.
Got to around 230-240 and felt "pretty" safe with hard braking.
Yeah, I think I'll need my 6-pots for if I ever get to 260-270 :P
  • 2 months later...
Entry is in! Looking forward to it - and hopefully not as much waiting around. But then, that is always going to be the case with an event like this. They do say that in motorsport, one of the phrases often used is "Hurry up and wait"!
Hope to see you guys there. :action-smiley-069:
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
