1998 200sx S14a Luxury in Jungle Green
Australian Delivered
147000 Kms
Manual
Strong Engine Tuned in August and all fluids and oil changed.
Modifications
GT2871R Turbo
Braided oil and water lines
Alloy Radiator
HKS S/S dump pipe
Tune agent S/S front pipe
Custom Cat Back exhaust
GK Tech Front Mount, return flow (legal)
BC BR Coilover, adjustable camber tops, height and stiffness
GK Tech adjust suspension arms all round
Tomei 1.5LSD
Nismo 740cc injectors
Work Emotion CR Kai rims with Federal RSR's all round
Apexi PowerFC with han d controler and Greddy Profect B incabin boost controler
Viper alarm and immobiliser
Apexi Boost Gauge
Pioneer Head Unit
Pod Filter with GK Tech Cover/Box
Braided Brake Lines
Just fitted Phillips 4800k HD globes last month
Tuned by Chasers in August - Conservative tune of 210rwkw at 16psi definatley more in it with more boost I was happy with the 210rwkw, drives great lots of response and pulls hard all way to redline, hooks up really well with the Tomei 1.5
There are lots of standard parts that will also come with the car, exhaust, suspension parts, ECU, injectors and fuel rail.
All parts are just on a year old and close to $7000 was spent to get the car where it is today. Paint is very good for the age with your usual small blemishes here and there. Interior is in great condition.
Looking for a quick sale due to a business opportunity so will let go for $10,500 with no rwc as I dont have the time. Nearly all standard parts come with the car for the road worthy anyway.
PM me or give me a call 0409 406 844
Cheerspost-1729-0-13264400-1382430472_thumb.jpgpost-1729-0-12265200-1382430846_thumb.jpgpost-1729-0-04342500-1382430886_thumb.jpgpost-1729-0-62403600-1382430909_thumb.jpgpost-1729-0-76030000-1382431025_thumb.jpgpost-1729-0-15711200-1382431048_thumb.jpgpost-1729-0-12636000-1382431075_thumb.jpgpost-1729-0-14247000-1382431215_thumb.jpg
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
