As title says, could a 4 door sedan version of the R32 have enough space for some music equipment? Would I be able to fit all at once:
  • 2x 15 inch PAs
  • 2x heavy duty speaker stands
  • 1x 50W Valve combo amp. Maybe another amp of comparable size
  • 2 guitars in retangular cases
  • An acoustic guitar
  • 2 mic stands
  • Guitar rack (fits 6 guitars)
  • Few other small percussions like tambourines etc I don't have much
  • Medium-large storage box (containing leads and power plugs etc)
  • Possibly a keyboard (optional)
I probably won't be bringing everything listed here but incase I need to it's always good to know if it's capable. Maybe I should take a pic of all the stuff?
Reason for choosing the R32: I considered R31s but I just know that eventually I will be disappointed in the handling coming from an SW20 MR2. I don't want to buy a Van yet without having a fun car to drive around but I can't afford 2 cars at the moment. With the MR2 I could fit 2 PAs speakers and a few more things by removing the passenger seat but still need much more space. Also, I think I've been bitten by the RB engine eargasm bug :wacko: and I've always wanted to experience a turbo car. At least the R32 is more track ready than either a R31 or a dare say the van lol. Mate just bought an R33 so I want something different and from quick reading the R32s are lighter and more chuckable out of the box.
If there are any meets in Victoria coming up soon I'd be keen to check out a few to take some interior measurements :D
Cheers
Thanks for the reply fellas I guess it was wishful thinking...I know I'm being stubborn here but I reckons I could make it work lol. Shame about the seats not being able to fold down. The Stagea is outta my price range and it's the perfect fusion between performance practicality but I think I'd rather separate that into sports car and van, whereas I'm looking more sports car with some practicality.
I'm not always gonna be lugging around this stuff but when I occasionally do I'll just take out the rear seats - how often do you even get pull over for that? Drove around with the MR2 without passenger seat plenty of times haha
Anyways if I decide to go ahead an get an R32 4 door I'll let you guys know how much I was actually able to squeeze and take a couple pics :thumbsup:
RE Attached pic: 2 speakers on the front seat, rear boot actually perfectly accomodates my rectangular guitar case (lucky!) OR a compact e-drum set. It's a stretch but I think the 4Dr R32 can do it!!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
