Need to sell my 1990 R32 Maroon GTST, don't have the time/money/interest that a skyline needs so has to go.
Bought it 6 months ago for $8500
75 XXX km's
REGISTERED UNTIL MID NOVEMBER
Located in Brisbane
THE GOOD:
Serviced ~500km's ago including new oil + filter, spark plugs, fuel filter
Rego
Recently passed RWC
Previous owner spent a lot of time and money on the car and I've only put about 1000km's on it since
Genuine timing belt kit + tensioners + idler pulley
Genuine Nissan water pump with timing belt
Injectors SONIC cleaned + new O ring washers
Near new Apexi pod filter
Nissan thermostat
ALL exhaust studs replaced
Exhaust manifold gasket
Turbo to manifold gasket
Alloy radiator with standard shroud and fan
Grex Oil cooler with U.S.A. sandwiches and re-locator (relocated driver's side behind front bumper)
APROF aftermarket side-mount intercooler (original location)
3" turbo back exhaust - Quiet the car goes unnoticed when cruising
EXEDY Heavy Duty ceramic button clutch
Slave cylinder replaced
Throw out bearing replaced
Brake master cylinder replaced
Brake pads replaced front and rear
Brake fluids replaced
Factory LSD serviced
Car was recently aligned at Fulcrum Stafford, still have receipts and readout
THE BAD:
Cars starts and runs every time, but is having some sort of fuelling/intake issues. The car is drive able under light throttle however under moderate to heavy load the motor will just bog.
Ive taken the car to mechanic (East Coast Kustoms) said the fuel pump and idler control valve needs replacing. Also the coil packs probably need replacing as a start. Pretty much I don't have the money or interest to fix this problem.
Also LH Front Quarter has minor damage - see picture
Front bumper is black - See picture
No air con
The car doesn't need major work or money to fix the above problems just someone who is interested in it. I just need a car to get to work/study.
Looking for $3500 - will consider all offers
Or will swap for rego'd daily car in good road worthy condition around similar price.
Text/Call 0417 729 704
https://www.sau.com.au/forums/topic/433830-for-saleswaps-r32-gtst-qld-3500/
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
