hahahahahahah the home made sticker suddenly made it legit...
maybe would sell better if they had a home made Z tune sticker...
Strongly recommend the black 1999 "vspec 2" currently at Edward Lees, complete with epic front end hit and home made vspec 2 sticker.
Great buy.
"That Supra was a one off. We stand by every car we sell. We can supply you with the documentation from japan that is just as strictly "corrected" as our speedos. Just let us know if you'd like a particular car with a certain number of kms and we'll organise it for you."
LOL
How about the white RX-7 on the website? 56,000km and steering wheel and drivers seat have double the wear of my 200SX thats got 115,000km now.
There is also a black FTO with 68k - judging from pics, in the same condition as my woman's Mirage, that rolled over 165k now, and been used daily without much special care. What a joke
Edited by junkie
" Just let us know if you'd like a particular car with a certain number of kms and we'll organise it for you."
actually they werent lying... they just didnt say that they will FIND a car matching your criteria, they will find one and wind the kms back to the number u like... LOL
"Hey I'm looking for a R32 with 60,000km, can you find one for me"
"Woah its your lucky day, I have one in stock right now........ its off getting 'detailed' so you cant see it today but tomorrow, sure think!"
I passed EL on my way home today. There were two groups of guys checking out cars there.
Only if these guys did a little research before spending their money!
Meanwhile all was quiet next door...
  • 7 months later...
  • 1 month later...
Bought a car from them before I found out about what goes on, similar story to most of the others above. Have recently obtained the dereg certificate from Japan, my car apparrantly lost 60,000kms from its speedo between getting its export certificate and being cleared through customs in Australia. Also dont trust auction sheets as proof, if there are no books or deregistration certificates, dont bother.
  • 3 weeks later...
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
