Hi, just have some questions here..
RB20det standard injectors are approximately good for how much rwkw's?
My rb20 just went in for a full rebuild, and i purchased a garrett gt28 bb turbo - .70 comp cover, 0.64 exhaust housing, rated at 400hp. The wastegate actuator spring is rated at 11.8lbs.
Now does that mean with the spring rate my minimum boost is 11.8psi? Because im a little worried about my injectors not being able to keep up with the turbo. I was planning to run about 8-10 pound initially, then once i upg fuel system i wind up the boost. I have a hybrid ebc btw.
Any thoughts/insight would be appreciated.
https://www.sau.com.au/forums/topic/43388-rb20det-information/
I would upgrade your injectors because they will be completely maxed at that boost level id say if getting a little on the lean side with the gt28, they arent an expensive mod so it will be worth it so you can use the potential of the turbo.
Thanks for the input v8eta,
Mase: Yes they are a straight swap, although i think they need a dif plug? But the general consensus of the threads i have been reading is that those injectors are designed for a rotary engine, the spray pattern being suited for that not so much a piston engine and apparently are a bitch to tune.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
