Hi guys, i have recently added a 32 to my collection :) and it has disintegrated rear
subframe bushes. So much so, big chunks of it fell out when i jacked one side from the subframe mount :P
Ive had a look around and see that there are solid,locking,pineapple,hardened rubber and poly options. And also the significance of offset for angle in regards to grip and such.
My question is, what are my viable options in regards to handling and grip without going solid alloy bushes? Im thinking Poly, but what is the best brand to go with? unless the hardened rubber is the best way to go. Is there anything else to consider? and if i decide to go with a full bush kit for the car, which company has better product for this model?
Cheers in advance guys :)
Apologies if i have missed a vital thread in regards to this information.
I used the Whiteline hard rubber ones in mine and they are good. Previously had original + pineapples and the current set up is at least as good as that (I mean.....how do you go about quantifying how much tighter one is than another anyway!!?)
I went with Whiteline all around (diff are solid bushes). The only issue I had with them is that the subframe sits very high now, so much that I think I need spacers made up (1-1.5") to drop it back down to stock as it affects my antisquat. Can't find any info as to it being normal or not.
I used solid alloy bush inserts, not the press in ones, the ones that fit on top of your old worn rubber ones , the upper ones were a C section so you only had to loosen the subframe a little to slip them in.
Tightened up the rear a lot, only a little extra road noise through the cabin.
Just go pinapples for now, they sit in between the subframe and the beveled washer and nut. Installing it in standard fitment will reduce subframe movement.
Of course, best solution is to drop the subframe, drill out your dead bushes and press in New whiteline or superpro ones.
Slip in collar work better when you're bushing is semi shagged, if they're totalled like yours are then the collars have no where to sit and end up moving around causing some chatter.
Cheers mate. Which is the better brand to choose? Are their bushes the same or is there some difference in performance and offset or whatever?
stick to SuperPro OR Whiteline.. can't go wrong :)
Just get whatever is in the catalog
Superpro dont do the actual bushes yet. they are hummin and harring about making them thus far. As far as it looks i will be going with whiteline bushes and maybe also pineapples. unless someone has some mental good bush kit that i can get from america or something.
Streeter with future outlook for definitely more power ( has built 25) and possibly tracked. But yeah for now for maybe a year or so streeter. I just want the good stuff as I have the money to back it up.
if that's the case just get full replacement whiteline subframe bushes, drop the entire subframe pop in the new bushes.. at the same time buy some GKTech subframe re-enforcement plates and get them welded on...
scrub up the sucker and re-spray it too.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
