Hi guys, i have recently added a 32 to my collection :) and it has disintegrated rear
subframe bushes. So much so, big chunks of it fell out when i jacked one side from the subframe mount :P
Ive had a look around and see that there are solid,locking,pineapple,hardened rubber and poly options. And also the significance of offset for angle in regards to grip and such.
My question is, what are my viable options in regards to handling and grip without going solid alloy bushes? Im thinking Poly, but what is the best brand to go with? unless the hardened rubber is the best way to go. Is there anything else to consider? and if i decide to go with a full bush kit for the car, which company has better product for this model?
Cheers in advance guys :)
Apologies if i have missed a vital thread in regards to this information.
I used the Whiteline hard rubber ones in mine and they are good. Previously had original + pineapples and the current set up is at least as good as that (I mean.....how do you go about quantifying how much tighter one is than another anyway!!?)
I went with Whiteline all around (diff are solid bushes). The only issue I had with them is that the subframe sits very high now, so much that I think I need spacers made up (1-1.5") to drop it back down to stock as it affects my antisquat. Can't find any info as to it being normal or not.
I used solid alloy bush inserts, not the press in ones, the ones that fit on top of your old worn rubber ones , the upper ones were a C section so you only had to loosen the subframe a little to slip them in.
Tightened up the rear a lot, only a little extra road noise through the cabin.
Just go pinapples for now, they sit in between the subframe and the beveled washer and nut. Installing it in standard fitment will reduce subframe movement.
Of course, best solution is to drop the subframe, drill out your dead bushes and press in New whiteline or superpro ones.
Slip in collar work better when you're bushing is semi shagged, if they're totalled like yours are then the collars have no where to sit and end up moving around causing some chatter.
Cheers mate. Which is the better brand to choose? Are their bushes the same or is there some difference in performance and offset or whatever?
stick to SuperPro OR Whiteline.. can't go wrong :)
Just get whatever is in the catalog
Superpro dont do the actual bushes yet. they are hummin and harring about making them thus far. As far as it looks i will be going with whiteline bushes and maybe also pineapples. unless someone has some mental good bush kit that i can get from america or something.
Streeter with future outlook for definitely more power ( has built 25) and possibly tracked. But yeah for now for maybe a year or so streeter. I just want the good stuff as I have the money to back it up.
if that's the case just get full replacement whiteline subframe bushes, drop the entire subframe pop in the new bushes.. at the same time buy some GKTech subframe re-enforcement plates and get them welded on...
scrub up the sucker and re-spray it too.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
