Hi guys, i have recently added a 32 to my collection :) and it has disintegrated rear
subframe bushes. So much so, big chunks of it fell out when i jacked one side from the subframe mount :P
Ive had a look around and see that there are solid,locking,pineapple,hardened rubber and poly options. And also the significance of offset for angle in regards to grip and such.
My question is, what are my viable options in regards to handling and grip without going solid alloy bushes? Im thinking Poly, but what is the best brand to go with? unless the hardened rubber is the best way to go. Is there anything else to consider? and if i decide to go with a full bush kit for the car, which company has better product for this model?
Cheers in advance guys :)
Apologies if i have missed a vital thread in regards to this information.
I used the Whiteline hard rubber ones in mine and they are good. Previously had original + pineapples and the current set up is at least as good as that (I mean.....how do you go about quantifying how much tighter one is than another anyway!!?)
I went with Whiteline all around (diff are solid bushes). The only issue I had with them is that the subframe sits very high now, so much that I think I need spacers made up (1-1.5") to drop it back down to stock as it affects my antisquat. Can't find any info as to it being normal or not.
I used solid alloy bush inserts, not the press in ones, the ones that fit on top of your old worn rubber ones , the upper ones were a C section so you only had to loosen the subframe a little to slip them in.
Tightened up the rear a lot, only a little extra road noise through the cabin.
Just go pinapples for now, they sit in between the subframe and the beveled washer and nut. Installing it in standard fitment will reduce subframe movement.
Of course, best solution is to drop the subframe, drill out your dead bushes and press in New whiteline or superpro ones.
Slip in collar work better when you're bushing is semi shagged, if they're totalled like yours are then the collars have no where to sit and end up moving around causing some chatter.
Cheers mate. Which is the better brand to choose? Are their bushes the same or is there some difference in performance and offset or whatever?
stick to SuperPro OR Whiteline.. can't go wrong :)
Just get whatever is in the catalog
Superpro dont do the actual bushes yet. they are hummin and harring about making them thus far. As far as it looks i will be going with whiteline bushes and maybe also pineapples. unless someone has some mental good bush kit that i can get from america or something.
Streeter with future outlook for definitely more power ( has built 25) and possibly tracked. But yeah for now for maybe a year or so streeter. I just want the good stuff as I have the money to back it up.
if that's the case just get full replacement whiteline subframe bushes, drop the entire subframe pop in the new bushes.. at the same time buy some GKTech subframe re-enforcement plates and get them welded on...
scrub up the sucker and re-spray it too.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
