  • Replies 42
I got about the same result from installing/tuning a safc2. 170 up to 181kw, same mods as you on stock ecu.
Main difference was comes on quicker and smoother after 4k rpm.
I think biggest benefit of the nistune is now you can do more mods for more power. (increase boost, bigger turbo, etc) none of this can be done on stock.
Mods = more power increase
ecu = how well you can use the mods.
personally I'd run the thing at way more boost until the turbo shits itself then get hypergear to highflow it. 11psi is still within what's acceptable on the standard ECU
Ever seen the after effects of a turbo 'shitting itself'? Usually costs around $2k for a new motor after most of the compressor has been through the motor.
I would say that's about what to expect; between 180-190 is pretty decent for an 18 year old motor that's probably down on compression since it left the factory. If you want more power, as suggested get some new injectors and a high flow turbo and you could see up to 250rwkw.
As for 'moar boost', that doesn't always result in more power, after around 12psi the standard turbo looses efficient and it won't flow any more air. There isn't much difference between 12 and 14 psi except for heat
A ceramic turbo will let the exhaust wheel out and end up in the cat nothing to do with the comp wheel. Its mainly a problem with GTR's when the ceramics fail there can be ceramic dust that ends up being sucked back into the chamber, i've never heard of this on a RB25.
I've never heard of someone blowing the motor as well when the stock turbo lets go.
Like James (Sklyn) I recently installed / Tuned an SAFC2 and found the Response, Midrange and Drivability improved greatly.
Totally Different car. Not sure what the before figure was but after the first tune I got 181.8rwkw. Much Better pickup.
That tune was backed off due to potential Timing belt issues.
I got the Timing Belt replaced and a retune saw a further increase to 192.4rwkw but this tune is also not to full potential.
My engine seems to want to start pinging when normally it wouldn't. My "Tuner" reckons it's acting as though the compression is higher than it should be. Maybe the head has been skimmed more than normal.
(Series 2 R33 RB25det, Pod, Metal intake, RB20 10psi Actuator on Stock Turbo, ARC smic, 3" Exhaust, Bosch 044 intank.)
But only being an SAFC, I would've thought a Nistune would open up alot more than 10kw.
I'd seek a 2nd opinion / tuner. Compared to an SAFC, something doesn't sound right...
On RB26 it happens frequently because there is a much more direct path from the turbine housing up into the exhaust manifold and exhaust ports for ceramic fragments to travel. The RB20/5 exhaust manifold makes it harder for that to happen (apparently). I say apparently because there are certainly fewer cases where a lunched turbine has trashed an engine, but if you trawl the net you will find the occasional death by ceramic even on these engines. My mechanic has seen more than one engine death that can be attributed to shattered 20/25 turbos.
And just in case anyone is still confused, it has nothing to do with the compressor wheel.
Yes sorry turbine not compressor*
It's quite common with the ceramics, my mechanic has seen heaps of them because apparently this theory of deliberately blowing it up is common. Can't understand it myself because it won't go any faster after the airflow is maxed so why push it any harder? Max the airflow and save for a new turbo and it won't cost you a new motor
He's already running 10-11psi with the R32 actuator. could put a little more but hardly worth it until highflow goes in.
Depends on what you're doing with what turbo. I ran my R32 ceramic at 17 psi for a couple of days and it was a bloody rocketship. Good intercooler helped to offset the probably fairly high compressor outlet temperatures, but the engine just kept making power as the boost was increased over the sensible max of ~14 psi. I think even though the old Hitachi turbos are not modern tech, they still operate just fine in the mid teens boost wise, so long as you can cool the air back down. It's not actually asking too much of them, except for the imminent risk of turbine destruction!
Edited by GTSBoy
DO you honesty think Nissan f**ked the factory tune up so bad that you could make more than a few killerwasps extra?
They didn't mess the tune up, however they added a heavily richened and retarded area to the map so that if you up the boost you don't blow the motor up, this results in a lack of power and very rich performance if you use a bigger turbo or more boost than stock, hence a retune can easily net > 20kw extra
and also remember with the factory restrictive exhaust system timing was shaven up top to prevent detonation.. same goes with S14/S15 maps.. just an exhaust mod & adding more timing from 5600 rpm will easily achieve close to 200kW with just 1 bar.
Seems to be a few different opinions on the power gain I should be getting with the ECU.
In the Sth East suburbs, I only know of 3 workshops that tune Nistune: RevZone(tuned my car), RE Customs and Springy Motors. I've heard good things about RE Customs but I'm not really sure it's worth me shelling out another $600+ for a handful of KW's when I will ultimately be getting a Hypergear H/F anyway.
Lol.
Good luck finding RE...
Springy lost their tuner afaik.
Never heard of RevZone.
Have you heard of Checkered tuning? Trent would be the best bet. It's not about the power, its the way it drives that would see marked improvement, with a decent tuner behind the keyboard.
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
