So yes I have 8 pot 330mm D2s on the front (same as K sports maybe?) and R32 GTR brakes on the rear but I think the D2s were an extravagance (need replacement rotors at over $1000 now) and would recommend the GKTech (its an Aussie company) big brake kit if it fits the Stagea (I think it should):
http://www.skylinesdownunder.co.nz/forums/showthread.php?t=67726
https://www.sau.com.au/forums/topic/433898-gtr-brakes/#findComment-7077151
s1 = anything to suit r32/r33
s2 = anything to suit r34
Have you put r34 brakes on an s2? I am asking as I have an s2 rs (rwd) that I have put r34 gtt brakes on. The bolts were m12, r34 brakes are m14. I machined new m12 inserts for the r34 calipers. perhaps rs vs rs4 is different?
https://www.sau.com.au/forums/topic/433898-gtr-brakes/#findComment-7077196
yup, mine is a s2 running r34 front brakes
must be the rwd part, front struts are similar to s15 from memory so apparently rwd is the exception to the rule there
should also add r32,33 and 34 rear brakes are the same
Edited by pipster11
https://www.sau.com.au/forums/topic/433898-gtr-brakes/#findComment-7077284
I've got a 32 D2 kit on my S1.....never had an issue with em.
Bob that replacement sounds expensive, have you tried a couple of places? In any case, at least you only have to replace the rings and not whole discs including centres
https://www.sau.com.au/forums/topic/433898-gtr-brakes/#findComment-7077865
The brakes themselves are great...but I got carried away at Hampton Downs a couple of weeks ago and got some serious metal to metal in the brakes. In fact they have been machined and look ok but the NZ agents for D2s cannot supply replacement rotors - only pads. I have asked around and the only source I have found are Race Brakes and they will be AP rotors (of which D2s are copies).
I haven't tried the Aussie rotor manufacturers yet but will do.
https://www.sau.com.au/forums/topic/433898-gtr-brakes/#findComment-7078424
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
