Hey everyone one I know I need to go see a mechanic but was wondering could anyone shed some light on my problems
My car has done a tad over 88,000 ks
2 problems not sure if there related
1st : my car seems to idle very weird the car ideals at about 1100 on a cold start up after a few minutes I drops down which I believe is normal problem is once the car warms up it idles very low and bounces between 550 to 800 and the car seems bumpy/splutery when sitting there!
2nd : my fuel consumption is crazy!! I am lucky to get 200ks to a tank most of the time 180ks my tank takes 50 liters and cost about $88 always premium you I drive a little reckless sometimes but not completely thrashing the car and I consistently get these ks only
Any I for would be greatly appreciated and if anyone know any good skyline mechanics in the northern suburbs of Melbourne (mill park, thomastown, heidelberg,Epping) please let me know thanks again
Jeff
https://www.sau.com.au/forums/topic/433913-1996-gtst-manual-fuelidle-problems/
Highly doubt it will have anything to do with the O2 sensor. Melbourne suburban driving is predominantly stop / start, accelerate / decelerate; not conducive to the ECU paying any attention to the voltages coming off the O2 sensor. If you want to check the health of the O2 sensor, try getting on the Hume and CRUISE up to Albury, then check fuel economy.
Low &/or erratic idle will usually be associated with a dirty AAC valve. Additionally:
- get injectors cleaned
- check fuel pressure at the rail.
The biggest cause of poor fuel economy is the lump of lead attached to the end of the right leg. FWIW, the RB25DET in my R32 regularly gets 400k+ to a tank, in Melbourne suburban driving (includes "a little reckless sometimes").
May I offer a spot of advice here - it is not necessary to hit boost through every gear change when you have a RB25DET. The engine has more than sufficient torque to get even the whale that is the R33 up and boogeying without the use of boost.
Unplug your TPS and set your idle flat on 650rpm, check your base timing, will need to be at 15 BTDC then replug in TPS.
See how that goes, then if you have a multimeter, check your coolant temp sensor.
Mine was faulty and my car would idle at 12:1 AFR, changed it and bamm back to stoich.
The ECU might always think the car is cold and dump in more fuel
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
