Continuation of my previous
"rb25 refuses to start thread"
What I know:
1) old fuel has no effect
2) must hold throttle open to start only when cold, may take 4-5 attempts. When hot engine starts fine.
3) still getting codes for AFM and TPS, even after reset
4) AFM voltage reads fine at off,idle and reving- there are no spikes/dips
5) AFM wire was lengthend to adjust to 240sx bay. Shielded cabling was not used.
6) At part throttle will rev to redline.
I do not understand what is happening. I thought if the AFM was at fault the engine would not rev past 2000 rpm at all, but it does. I measured voltage at the ECU harness while going WOT. Voltage did not reach 5V at any time. The rpm would build to ~2500 rpm fall back to 1000 rpm and back to 2500 rpm, etc.
Would unshielded wiring cause this? I'm out of ideas..
My moneys on an AFM wiring problem for sure if not the AFM itself. The fact that you have modified the wiring to the AFM makes it the number one suspect. If the connection to the AFM is faulty if can cause the ECU to go into limp home mode which in effect rev limits the car to around 2500-3000 rpm. This is something that I have experienced in the past after not checking that my AFM plug was fully clipped onto the AFM.
Hope this helps
I know its clutching for straws, but check all your piping which gets pressurised - you could have blown an intercooler hose or something like that, car is throwing in fuel for air it isn't receiving when it comes on boost.
Just adding a possibility to the mix :headspin:
I forgot I had an issue with tps voltage. Since I'm using a q45 tps I had to splice wiring. Turns out I wired the power the wrong way- so Idle was reading 4.5v, WOT at .6v. I rewired it and adjusted to .6v at idle.
Guess what? That fixed it the rev limit problem. Strange..
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
