Continuation of my previous
"rb25 refuses to start thread"
What I know:
1) old fuel has no effect
2) must hold throttle open to start only when cold, may take 4-5 attempts. When hot engine starts fine.
3) still getting codes for AFM and TPS, even after reset
4) AFM voltage reads fine at off,idle and reving- there are no spikes/dips
5) AFM wire was lengthend to adjust to 240sx bay. Shielded cabling was not used.
6) At part throttle will rev to redline.
I do not understand what is happening. I thought if the AFM was at fault the engine would not rev past 2000 rpm at all, but it does. I measured voltage at the ECU harness while going WOT. Voltage did not reach 5V at any time. The rpm would build to ~2500 rpm fall back to 1000 rpm and back to 2500 rpm, etc.
Would unshielded wiring cause this? I'm out of ideas..
My moneys on an AFM wiring problem for sure if not the AFM itself. The fact that you have modified the wiring to the AFM makes it the number one suspect. If the connection to the AFM is faulty if can cause the ECU to go into limp home mode which in effect rev limits the car to around 2500-3000 rpm. This is something that I have experienced in the past after not checking that my AFM plug was fully clipped onto the AFM.
Hope this helps
I know its clutching for straws, but check all your piping which gets pressurised - you could have blown an intercooler hose or something like that, car is throwing in fuel for air it isn't receiving when it comes on boost.
Just adding a possibility to the mix :headspin:
I forgot I had an issue with tps voltage. Since I'm using a q45 tps I had to splice wiring. Turns out I wired the power the wrong way- so Idle was reading 4.5v, WOT at .6v. I rewired it and adjusted to .6v at idle.
Guess what? That fixed it the rev limit problem. Strange..
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
    • 40 grit sounds about right, to start. You make some decent cuts/damage in the coating with that, then rapdily scale up to maybe 80 and 120 for the bulk of the actual removal, then fine it off to 180 or 240 perhaps. No need to go any finer than that, and maybe no need to go even as fine as that. Wrap it on a big block and have at it. At least on the hub face.
    • Do the GKTech rear lower control arm mount relocation, and either alloy subframe inserts or very stiff subframe bushes. Traction is going to be at a premium!
    • Hello,   My name if Frederick, i'm 30 years old and I live in Belgium, Europe! I used to have a Nissan 370z daily but since I got a company car I turned that into my seattime driftcar. About 3 years ago I also wanted something older with more feel, so I got an R32 GTST with an rb26 engine. I am now getting the rb built to have around 800hp and it's close to being finished. I'm very excited for how it will drive and how driveable it will be! Regards, Fred!
