My R32 is down on power over the entire rev range but mainly down low, it feels very doughy and laggy even though it builds boost very quickly, perhaps even quicker than normal like it is running on the cold start map (retarded timing)
My car is an r32 skyline with rb25det neo with r33 intake and ancilleries, highflow (gt2871r spec), 740cc injectors, r32 rb20det ECU with nistune, z32 AFM and upgraded fuel pump making 260rwkw, it still feels fast on full boost but not as fast as it should be, down low it feels like an rb20, laggy and gutless. Overall it still runs well, eg idle feels fine and it doesn't miss or run rough, it doesn't have flat spots or feel like I've blown a headgasket or rings, it generally feels like it just has had heaps of timing taken out of it.
I first thought it was the knock sensors so I checked ECU talk and it said no error codes, to be 100% I unplugged the knock sensor and it ran much slower again proving it wasn't the knock maps.
The next thing I thought was the VCT solenoid was stuck even though I could still hear it clicking in the engine bay, so I unplugged my boost controller (controls the VCT) and it got even slower again ruling this out.
One thing I can think of is the fuel pump isn't giving enough fuel (still on stock wiring with 8/14v switchover) however it is still down on power when on full boost which imo makes me think it isn't this and it has been fine for the last 2 years.
One other is perhaps the coolant temp sender is shagged, what would this show as in ECU talk, is it the analog temp sender eg I would see 0c from this sensor, or is it a digital on off sender that shows as something else?
Finally the only other thing I can think of is there is a boost leak, though my vac looks healthy at idle and there aren't clouds of black smoke behind the car.
Other than taking it to my tuner and sticking a probe up its ass to see if it is running excessive rich or down on timing what else could cause these problems?
Cheers :)
Edited by Rolls
  • Replies 51
It's an extensive list Rolls, it could be so many parts causing power to drop. I would start with checking the cat isn't blocked, and pressure testing the intake for leaks. Work your way through the free diagnosis and only replace parts once you know they are faulty, or it will cost you plenty. Check the condition of the plugs too.
One thing that does come to mind, the wastegate may need some more preload, usually 5mm is perfect. You can simply stick a few washers under the actuator.
Scotty it feels slow even on full boost at 3k so I doubt the wastegate is the issue. Things that I think are next on the list are fuel filter, pressure test intake, drop exhaust.
It isn't pinging though so fuel filter/pump I feel are unlikely.
Edited by Rolls
if it feels like its had heaps of timing out, could it be a CAS issue...
I thought about this but does it ever actually happen in the way I am seeing? I thought if it was an issue it would cause pinging (advanced timing) / loss of power (retarded timing) in the high revs where its effect is worse, not the opposite which I am seeing eg low power down low but up top ok.
Edited by Rolls
What fuel are you using Rolls? I ask because I've been generally a bit disatisifed with my Neo too the last couple of weeks. I would suggest that the mix coming from the refinery has changed lately (winter into summer)and would be tempted to put down some or all of my car's lack of sparkle to that. I'm not trying to tell you that there's nothing wrong with your car, but given that we both driving around the same place in basically the same car....it's a possibility.
Definitely check ECU coolant temp sensor (the 2 wire one) and definitely check fuel system (despite lack of ping).
I have had cars drop a pump or reg and not ping, but lost lots of power everywhere. Like you noted, with a blocked filter I encountered mega ping/hesitation, but I still wouldn't rule it out entirely.
These are definitely your first point of call.
With the temp sender what does it do when at temp, ground the voltage coming to it? Or is it a resistive element giving an analog temperature? What would be the best way to check it? I'll check all of my filters tomorrow and also fill up with a full tank of fuel.
edit: I guess the CAS could have just shifted, I'll see if it is tight.
Edited by Rolls
Rolls, the coolant temp sensor is a resistor. Varies with temperature.
Easy to check. The temp vs resistance relationship is google-able. Then all you have to do is measure the resistance when the sensor is at a known cold temperature and at a known hot temperature (take it out and put it in hot water with a thermometer) to see if it is on spec or not.
mine broke the bracket...no idea how, but it was very sluggish coming onto boost..pretty rare thing to happen i imagine..
https://dl.dropboxusercontent.com/u/1428435/revs.xlsx
here is a datalog I did, runnign around 35 degrees timing at ~2000 rpm full throttle about to come on boost. at 3-4.5k full boost running about 27 degrees then drops to 19-20 when on full torque.
Do these numbers sound abotu right? Full boost isn't until around 4k in 2nd gear.
Coolant temp sensor seems right reading about 60 degrees as I only just warmed the car up.
My speedo cable is broken so speed was wrong
Edited by Rolls
it looks a little low to me, I would have thought it should be around 25 degs, but without knowing what the timing map looks like I can't be sure.
One of the tuner around here will have more insight than my noob opinion.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
