Thinking of running a Car Boot Sale - Swap Meet early in January on a Sat morning.
It'd help to...
* empty out your garage for space
* create cash for after-Xmas sales
We'd need a shady place being in the middle of summer.
Eftpos will be available
Thoughts? Suggestions?
https://www.sau.com.au/forums/topic/433991-car-boot-sale-eoi/
It'd help to...
Are you sure you're referring to the heat, and not the person/s involved in this trading? :whistling:
I'd b keen as, as long as it's mainly skyline parts.
God_speed came up with an idea that makes a whole lot of sense Dean, that..,
If there are enough sellers and buyers, perhaps we should have 4 quadrants...
1 for R32s
1 for R33s
1 for R34s and
1 for other Nissans
Thoughts?
And thoughts of a venue?
Don't know if its feasible but there are always alot of swap meets etc at the Hawkesbury show grounds at Clarendon?
1 for R32s
1 for R33s
1 for R34s and
1 for other Nissans
Thoughts?
I'm sure if we ask the local council (wherever it maybe) to use a car park etc... it might work... Probably you guys might object to the idea, but how about the German Club in Cabramatta? there's a massive carpark which is pretty empty during the day
PS. the area has changed, you won't get shot or stabbed, probably safer than the city if you ask me.. just lock your doors and have a pole ready when you're driving through Farifield, Livo and everything surround it LOL
    • At least you're now aware of the problem and can come up with a solution.
    • Dang. Keen for further updates when you get to it.
    • Welcome to SAU Thomas, sounds like you'd had a bit of a an unlucky start with the car, hopefully you get some better luck now!
    • 1. No need, it only gets used once then is locked in place by the nut 2. EN-62 point 6 shows the conical washer the other way around (BTW I know we discussed above, I hope you are changing the idler as well, while it is no guarantee the bearing is a actually bad, it looks terrible) 3. I'm not really clear on the question, are you worried because it was easy, not hard, to remove the custom timing trigger? As long as it doesn't spin on the crank (when the bolt is tight) all good 4. Yeah just make sure the brand is easy to read as it rolls past 5. The part number is on the listing under the description, 13023-42L00. Given there is a custom part on there for timing (presumably outside the cover), they may have decided to leave that off; I think I would put the washer in there as it also helps seal the timing case from crap getting in.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
