Thinking of running a Car Boot Sale - Swap Meet early in January on a Sat morning.
It'd help to...
* empty out your garage for space
* create cash for after-Xmas sales
We'd need a shady place being in the middle of summer.
Eftpos will be available
Thoughts? Suggestions?
https://www.sau.com.au/forums/topic/433991-car-boot-sale-eoi/
It'd help to...
Are you sure you're referring to the heat, and not the person/s involved in this trading? :whistling:
I'd b keen as, as long as it's mainly skyline parts.
God_speed came up with an idea that makes a whole lot of sense Dean, that..,
If there are enough sellers and buyers, perhaps we should have 4 quadrants...
1 for R32s
1 for R33s
1 for R34s and
1 for other Nissans
Thoughts?
And thoughts of a venue?
Don't know if its feasible but there are always alot of swap meets etc at the Hawkesbury show grounds at Clarendon?
1 for R32s
1 for R33s
1 for R34s and
1 for other Nissans
Thoughts?
I'm sure if we ask the local council (wherever it maybe) to use a car park etc... it might work... Probably you guys might object to the idea, but how about the German Club in Cabramatta? there's a massive carpark which is pretty empty during the day
PS. the area has changed, you won't get shot or stabbed, probably safer than the city if you ask me.. just lock your doors and have a pole ready when you're driving through Farifield, Livo and everything surround it LOL
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
