For sale, most parts brand new in boxes, perfect condition, bought for build that never happened. Prices neg
Bought for an R33 Gtst but most parts will suit any RB25.
ENGINE PARTS
1 x Bosch Z32 AFM..................................................................................$350
1 x Gates Micro-V Power Steering Belt - Nissan CA18/RB25.....................$20
1 x Gates Micro-V Water Pump/Alternator Belt - Nissan CA18/RB25 ........$20
1 x Gates Racing Timing Belt Kit - Nissan RB Engine (includes Gates Timing Belt, NSK adjuster bearing, NSK idler bearing, camshaft & crankshaft seals).......................................................................................$250
1 x Genuine Nissan N1 Water Pump - Nissan GTR...................................$350
1 x Genuine Nissan Intake Manifold Gasket............................................$80
1 x Genuine Nissan Exhaust Manifold Gasket.........................................$100
2 x Genuine Nissan Rocker Cover Seals.................................................$60
2 x Genuine Nissan Half Moon Seals - Nissan RB/CA Engine....................$10
1 x Genuine Nissan Exhaust Manifold Stud Kit (includes studs, washers, nuts etc).....$100
1 x SRI Magnetic Sump Plug - Nissan........................................................$10
1 x Greddy Trust Oil Cooler with braided lines & fittings (2nd hand).........$500
1 x Plazmaman Intake Plenum (2nd hand) with (new) gasket....................$750
1 x Q45 Throttle Body & Gasket (2nd hand).............................................$175
1 x Standard rb25 throttle body (2nd hand)..............................................$100
1 x Nissan Power Steering Pump (2nd hand)............................................$150
TURBO PARTS
Garret GT3076R Turbo Kit (with internal wastegate) - all parts brand new in boxes.......$2400
INCLUDES:
· Garrett GT3076R Turbo with Actuator
· 0.82 A/R Rear 5 bolt, T3 in, 4 inch Compressor inlet
· 5 bolt dump pipe flange
· Oil and Water Line Kit
· Gasket Kit
· Oil Drain Kit
· Spacer Kit
· Stud Kit
TRANSMISSION
1 x Exedy Heavy Duty Button Clutch Kit NSK-7056HDB - RB20 & RB25..............$500
OTHER
2 x Project Mu B-Spec Brake Pads (Fronts).........................................................$200
1 x Nissan Oil Filler Cap.......................................................................................$50
1 x HID Headlights kit H1 35W/4300K...................................................................$150
20 x Project Mu Wheel Nuts.................................................................................$50
1 x R33 S1 Stock Front Bar (White).....................................................................$200
1 x Walbro Fuel Pump.........................................................................................$150
PM or msg Sam on 0413905538
Located SoR Perth, prefer pick up but can post
post-72384-0-38087800-1382784803_thumb.jpgpost-72384-0-41336700-1382784827_thumb.jpgpost-72384-0-22415600-1382784855_thumb.jpgpost-72384-0-52006100-1382784878_thumb.jpgpost-72384-0-87474500-1382784900_thumb.jpgpost-72384-0-75890800-1382784921_thumb.jpgpost-72384-0-59000400-1382784940_thumb.jpgpost-72384-0-52382300-1382784960_thumb.jpgpost-72384-0-45576300-1382784982_thumb.jpgpost-72384-0-97790500-1382785004_thumb.jpgpost-72384-0-11914400-1382785031_thumb.jpgpost-72384-0-66660200-1382785054_thumb.jpgpost-72384-0-24558200-1382785075_thumb.jpgpost-72384-0-19599000-1382785092_thumb.jpgpost-72384-0-20519200-1382785115_thumb.jpg
Also for sale:
Nismo Oil Filler Cap.......................................................................................$50
JJR Silicone Radiator Hose Kit (Black).....................................$50
  • 1 month later...
  • 3 weeks later...
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
