I've tried researching thru SAU and I can't seem to find if this has been done. What I'm finding difficult is the translation between US, Brits, and all you Ozzie. Every country seems to have their own word for a part. For example here in the US what we call the hood, you call a bonnet. Or my favorite is when I asked about a trunk lid and I was asked what that was. You guys call it a boot. Not frustrated one bit cause I love learning about everything and other cultures but sometimes it hinders the researching process.
I bought my R33 without front turn signals on the bumper because the previous owner installed a JUN front bumper. Because no front turn, everything blinks fast. I find this annoying. This is what I've been looking for. . . I want to not install a front bumper turn signal but instead try to tap into the headlight housing corner bulb to blink when asked to but stay solid amber when not turning when the marking lamps are turned on. Then when the mark lights are off it would just signal. Make sense? I was wanting to install a front signal light but honestly haven't found a "style" I like. I was also considering making a carbon fiber ducts for the large inlets openings on the front bumper to channel air to front brakes. Has anyone tapped into those corner headlights to make them signal?
https://www.sau.com.au/forums/topic/434056-front-turn-signals/
Hey man I had a mate that did the same thing and encountered the hyper flash problem we used an led decoder to fix it there like $7 per unit from eBay {style_image_url}/attachicon.gif ImageUploadedBySAU Community1383186290.631249.jpg
{style_image_url}/attachicon.gif ImageUploadedBySAU Community1383186303.650900.jpg
I use these frequently on my semi-trucks and trailers when I swap the marker lights to LED. What I'm looking for is if anyone has wired the corner bulb in the headlight housing to be the turn signal and remove the front bumper signals?
I don't think many people would have done it because Australian road regulations require a front turn signal - and possibly 'headlight corner bulb' (= parker lights to us). So no, i don't think many would have done that.
Though, logically thinking about it, isn't it as simple as wiring the headlight loom to the parker bulb loom...? and sticking in a relay to reduce the flashing/controller unit to make it do what you want?
That's what I'd figure what to do also. Was hoping someone had an idea how to wire it and what type of relays or controller to use. Probably utilize the front bumper light wire??? Maybe add another bulb in the corner??? Maybe use a two filament bulb instead of the 194???
Funny thing is when I buy a car I look at three big things. Is the body perfect? Is the interior perfect? The electrical all working? I could care less about buying a car with horrible mechanical because I can fix it. Body... don't have the patience. Interior...extremely hard to find the small screw covers on a grab handle. Electrical... extremely difficult to trouble shoot hundreds of feet of wire for shorts.
I've been researching aftermarket ideas for something that might work. Had an idea to use a double filament bulb with some kind of new socket for it, install it somehow without destroying my housings, and using the front bumper wire to make it blink. What do you think?
I think that you know a lot more than me about this, and my own electrical knowledge is very limited. With this in mind, you really do have the freedom to do whatever you want, just make it work! Double filaments sound good - or use LED bulbs!
Hey Cole, You've mentioned nearly all my ideas. I ran a two bulb setup in my R32, as there was a bulb socket right behind the corner bulge. The only other method I can think of would be to use your turn signal wire to interrupt (via a relay) your marker light circuit. Here in Australia we have to have separate indicator lenses, but over there in the U.S. you guys, on your older cars had the exact set up your after (look at old mustangs & camaros) where the front marker lights & 1 of the tail light lense would flash for indicators.
If I were looking at doing the same thing, I would be tracking down & looking at wiring diagrams for vehicles like I mentioned. Failing that, I'd actually try & actually look at a car that has that sort of set up & trace it..
Good luck, It can be done!
Brilliant! Thanks!
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
