Does anyone know where I can get intercooler hoses (prefer rubber to silicone b/c of price factor) with 90 degree bends in them? I tried purple pig in sunshine as they specialise in these sorts of things but they only had straight hoses. The piping to my cooler runs to the factory plumbing, and the pipe that runs under the cooler hangs too low. If used a rubber hose instead of the pipes i had made up, I can avoid this problem...
Thanks
Zahos
https://www.sau.com.au/forums/topic/4341-intercooler-hoses/
I cannot see a radiator hose bursting at any sane boost level. There may be three inch moulded hoses made for trucks, busses, earth moving machinery and so on. If you can find them, they would be almost certainly extra heavy duty and be well up to the task.
Let me know how you go, because I have a future project requiring three inch moulded hoses, and I am too mean to pay eight hundred dollars for a GTR silicone hose kit.
I am also in Melbourne, and I think we should keep in touch.
My e-mail is: [email protected]
https://www.sau.com.au/forums/topic/4341-intercooler-hoses/#findComment-68713
Warpspeed:
Well if u only need straight hoses, then purple pig on McIntyre rd sunshine will be your best bet! The have silicone aswell, but its like $180 per meter :lol:
Just get some rubber hose, as its only a fraction of the price and it does the job. They also have clamps and other bits you might need.
R31 Skyline Chick:
Thanks for that. I'll give em a call and see how much they are, but i suspect that they will be ridiculously overpriced.
Zahos
https://www.sau.com.au/forums/topic/4341-intercooler-hoses/#findComment-68778
Hi Zahos. Yes, straight hose combined with some mandrel bends would be the cheapest and simplest solution. It would also flow very well. Moulded hoses are better though if the installation is really tight, and high flexibility is a prime requirement.
AVO had a special a few weeks back on the HKS silicone GTR hose kits. I think the price was reduced to somewhere around $500 ? from the more usual $800 for these kits. I believe the kit consists of four 90 degree bends. Better check with them though.
I am using a lot of GTR engine parts in a supercharger installation. As it is not yet fitted to the car, I am not yet at the stage of knowing exactly what the hose routing is going to be.
That is why I am extremely interested in anything that you can find out, but am not really ready to go searching myself. I do not yet know exacty what hoses I will need.
It must be possible to find a bit of three inch radiator hose with a ninety degree bend that costs less than $200 per bend ! ! !
https://www.sau.com.au/forums/topic/4341-intercooler-hoses/#findComment-68807
H.I.S. Hose have all the silicon stuff - straight and Bends - In a few colours too from memory...
This is one of the places that some of the turbo shops buy the stuff from..
158 wellington Road Clayton Ph 9560 9222
or
405 Francis Street Brooklyn Ph 9314 2255
I would have thought that the biggest problem with using Rubber Radiator hose is not bursting - but bulging - they would expand with boost... especially when they get hot?
James
https://www.sau.com.au/forums/topic/4341-intercooler-hoses/#findComment-68841
Thanks James. I might just go around to H.I.S. tomorrow and check them out. I have used radiator hose for years on turbo and supercharger installations. The stuff is made to handle heat and pressure, water or air does not seem to matter. Have had hoses blow off due to not being clamped properly, but have never had a single hose burst or rupture.
If you need a fairly sharp bend straight after the turbo, a bit of radiator hose in the correct shape is ideal. The only reservation might be that turbos tend to sometimes spit a bit of oil, and the hoses become covered inside with an oil film. But I have never had a hose actually fail on me, and I have run up to 20psi boost.
https://www.sau.com.au/forums/topic/4341-intercooler-hoses/#findComment-68856
Just got back from H.I.S, they carry almost no stock on the premises, but there are two three inch ninety degree bends in stock warehoused somewhere in Australia at the moment. Anything not in the country takes 8 weeks.
They can get 1 metre lengths of 3'' reinforced silicone hose at $190 plus GST.
The 3"reinforced silicone bends are very sharp, more an elbow than a bend. $135 plus GST.
The stuff I saw looked to be exactly the same as that shown on the Turbonetics USA website, and probably comes from the same original source.
https://www.sau.com.au/forums/topic/4341-intercooler-hoses/#findComment-69147
I am with you Zahos. It was an interesting exercise to go through though, at least if I ever need the silicone hoses I know where to get them in Melbourne.
When I can find some time it may be worth checking Ryco and Dayco, these are two companies that make the moulded hoses in Australia that I can think of off the top of my head.
There must also be places arouund somewhere that sell all the truckies accessories, but have no idea where at the moment.
Also companies like Kenworth, Caterpillar, probably have some suitable three inch hoses ?
https://www.sau.com.au/forums/topic/4341-intercooler-hoses/#findComment-69160
Yeah, probably is retail, but even with a trade order it is still going to be a bit expensive.
I have just returned from a nice little drive to Dandenong. On the Princes Highway south of Dandenong, there are a lot of trucking places. Finally ended up a place called Truckline at 2-10 Decor Drive, Hallam, ph 97023344.
They photocopied a page out of one of their catalogs for me. Now the big rigs usually have a vertical exhaust stack on one side, and an air intake snorkel on the other side, behind the cab.
The snorkels uses rubber bends and hump hoses in 3 inch, 3.5, 4, 5, 5.5, 6, 7, and 8 inch sizes. All the variants between 3 inch and 5 inch cost typically $20 to $30 each.
I asked the counter guy where they had to come from if they were ordered in, he said Scoresby. The photocopied page that I got says Tubengineers (with a turbo logo), and a phone number 9763-8066. But any truck place could probably get these hoses in the same day. The catalogue describes them as"Äir Inlet-rubberware".
Although they are simply plain rubber and not reinforced, the rubber is 7mm thick and pretty stiff. For the low cost, I think it may be worth a try. I bought a 45 degree bend that I have in front of me at the moment for $20.45
https://www.sau.com.au/forums/topic/4341-intercooler-hoses/#findComment-69205
I just called the manufacturer 1800 032 037, and asked them for a 3" 90 degree bend - part no: 3316566S
The chick on the phone didnt know if it was reinforced, and she also didnt know if it were rated to a certain preasure or heat rating. She put me through to an "expert", but he wasnt at his desk!
https://www.sau.com.au/forums/topic/4341-intercooler-hoses/#findComment-69213
Well the only concern might be the heat rating on the turbo side. If your intercooler is half decent, heat on the downstream side should not really be a problem though.
Because it is an atmospheric induction hose, it probably does not have a pressure rating. It is a bloody tough hose though, it might swell a bit under boost, but so what. For $20 well worth a try I think.
Where abouts are you Zahos? I am in the south eastern suburbs. Dandenong is no sweat, but Scoresby is a bit further for me.
https://www.sau.com.au/forums/topic/4341-intercooler-hoses/#findComment-69221
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
