Well at the moment i have stainless steel mandrel bends in place, but this causing a problem!
If you look at the pic of my cooler, you will see that one of the pipes runs under the coller to utilise the factory plumbing. The pipe I had made up to run under it, hangs very low!
I cannont cut the pipe coming out of the end tank any more as I have already chopped as much as i can off.
I cannot cut any more off the pipe running under any shorter either.
At the moment, the intercooler is sitting on an angle so that the pipe doesn't hang too low.
If i use A rubber hose with an elbow, I can get around this problem because then i can have bend coming right after the pipe on the end tank finishes. The pipe would then sit directly under the cooler, and this wouldn't be an issue.
If i had the cash to do that, i would probably get new end tanks made up for the cooler instead.... much cheaper alternative.
The intercooler looks a bit funny sitting on an angle, but it doesn't bother me enough to spend big bucks on it. I'm looking to buy a house now, so spending more cash on the car when i dont need to is out of the question for me...
Hello again Lowlux. I am collecting bits and pieces for my project, which will be a supercharged 33GTS-4. I am still looking for a suitable vehicle though. Eventually I am going to have to fabricate a set of extractors for it. The pipe sizes on the Jasma extractors are about optimum for a normally aspirated engine, but far too small for a supercharged RB26.
What grade stainless can you get, 304, 321 ? and what wall thickness ? I will need to buy a fair bit of this stuff, but cannot plan the exhaust until I actually have a car! Please e-mail me: [email protected]
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
