Up for sale is my Nissan Skyline R34 GT-T Import
I have owned the car for over a year and it currently has 86000km on it. I was the first registered owner of the vehicle in Australia, and have kept it in pristine condition inside and out.
The reason for selling this car is simply because it does not suit my lifestyle anymore. I have to drive 700km every month and dont want to put too many KMs on it. I have a cheap run about now and therefore need to sell.
The car is standard and no major modifications have been done.
Since owning the car, i have changed the spark plugs, ignition coilovers, various bushes on the front and back, have put BC racing coilovers on, painted the calipers red, put slotted rotors on the front, had 4 new tyres (1 month ago), changed the bulbs into the super white ones, changed the side lights to clear with orange bulbs, and sprayed the centre console to match the GTR interior (see picture).
The car will have all the original paperwork, 12 months rego (9th Nov 2014) and also has a Viper alarm and immobiliser and has shock sensors and window sensors (valued at $500). I also have a spare set of keys.
The car also comes with a Sony Bluetooth head unit with handsfree. rear speakers and a Sony Amplifier and Subwoofer.
I am open to offers, reasonable offers.
https://www.sau.com.au/forums/topic/434104-nissan-skyline-gtt-white-for-sale/
    • Yeah. OK. I'll say the same thing I say to everyone. You do not have to use 100% throttle all the time.
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
