No holds and no shotguns, nothing is sold till it's paid for or a deposit is put down.
I can ship anything anywhere if you pay for it. Pickup is available no probs.
RB-Z gearbox
RB bellhousing with Z32 rear housing (RB and Z32 gearsets are the same)
- bolts onto an RB-series motor, RB20, RB25, RB26, RB30
- comes with Z32 shifter setup (not pictured)
- great for RB-motor conversions
- if you have an rb30/26 for sale then let me know I might buy it from you and use this gearbox behind it.
Price: $950
Blitz I-color Spec R twin solenoid sequential boost controller with 3/4 optional extras
*** all up it's a boost controller with gear or speed sensitive boost, boost gauge, water temp gauge, oil temp gauge, oil pressure gauge, multichannel logging system and performance meter ***
- best boost controller hands down
- twin solenoid for stable boost control
- all in one monitoring system so you don't need 6 gauges across your dash
- includes the optional Blitz oil temp sensor, plug and play
- includes the optional Blitz oil pressure sensor, plug and play
- includes the optional Blitz auxiliary-in wiring harness, plug and play
- I set it up to monitor water temperature as well
- can also monitor stuff like throttle position, AFM voltage, injector usage etc
- includes a set of s15 sun visors where I've mounted the display
Price = $750
Auto Service MATSUFUJI s14 clutch pedal brace, may fit s15 and s13 but I don't know for sure.
This braces the clutch pedal bracket and stops it from flexing; is a good mod for those that run tuff clutches or likes to kick it once in a while. Stops the flex and stops the pedal bracket from breaking.
BRAND NEW
Price: $80
Price drop: $60
Price drop: $50
Brand new genuine Turbosmart 4" straight silicon
Price: $20
Other info:
Yep i-color is available (the sensor set is sold though)
Gearbox condition is meant to be good, I haven't used it myself as I'm still tossing up the RB30/26 idea. You're welcome to come check it out :)
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
