Link to gumtree ad with more photos
http://www.gumtree.com.au/s-ad/delahey/cars-vans-utes/1998-r34-skyline-manual-non-turbo-coupe/1030445670
Priced for quick sale
Cheapest r34 skyline coupe manual non turbo on the market
Selling as i have too many cars and dont have money to fix
Manual, Non turbo
200050ks on the clock
The bad:
Worn clutch, car can still be driven
Engine bay is still original colour red
Drivers side guard has mismatch white paint
Rear bar has mismatch white paint
Bootlid has mismatch white paint
Signs of repair on rad support to the drivers side
Gear stick needs to be secured, The pin for the gearstick is not cliped in
Brake pads and maybe discs/rotas
Parker light globes
Drivers side headlight bracket broken - needs repair
Tyres
Roughly $1000 needed to spend on the car to get a rwc, i dont have the money to fix so i have to sell
Its still registered for few more days but im selling the car as is with no rego no rwc
The Good
Cheapest R34 you will find
Manual non turbo perfect for a p plate driver
Engine and gearbox are perfect, the car can still be driven but with the worn clutch it wouldnt be going far so i reccomand getting the car towed
Interior is excellent condition, seat belts, seats etc are in roadworthy condition
18 inch rims and dvd player are not included with the car, i will provide stock wheels
Registration Details
Current SA Rego
Plate Type ALPHANUMERIC
Plate Number S397AUG
Make NISSAN
Body Type SEDAN
Primary Colour WHITE
Expiry Date 31/10/2013
Last VIC rego
Vehicle Registration Enquiry: Results as at 25/10/2013 04:01 AEDT
Vehicle Type Car/Truck
Victorian Registration Number XMC468
VIN/Chassis Number 6U90000ER34006163
Engine Number RB25287392A
Colour WHITE
Make NISSAN
Body Type SEDAN
Compliance Plate Date 06/1998
Year Of Manufacture 1998
Transfer Dispute No
Registration Serial Number 4063998
Registration Status Cancelled
Registration Expiry Date Not Applicable
Sanction(s) Applicable No
$6000 is a bargain, looking on carsales non turbo r34s go for 10k+
Pickup only from Delahey Vic
Please send me a text if intrested 0422 747 913
I am ussaly busy with work and cannot answer calls so text message is perfered
Edited by Johnie
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
    • Can you covert an R32's AC from r12 to r134 if the compressor/hoses etc are still all good? Pretty sure on my car the AC was degassed when it was imported  to remove the naughty r12 and save the ozone layer, and the fancy climate control system just blew air around. Was happy to drive the car with windows down back then, but now I am old and need to be kept cool
    • Just to circle back here, I've sold my automatic trans to another Stagea owner in OH.
