Hi all,
cant find from searching,
will a Nistuned ecu from a manual R34gtt adapt into a C34 RS4-S stag?
appart from obviously needing to be retuned is there anything different which would stop this from working?
would i need to separate the board or could i swap over the ecu itself?
thanks for any help.
glyn.
https://www.sau.com.au/forums/topic/434143-r34gtt-nistune-rs4s/
You should be ok as all the maps and settings you can see are the same however the issue of traction control and what Nistune does with it might cause some background issues.
The board can have the correct base image loaded onto it by Nistune or some of the dealers with desoldering gear but that will cost around $50-75 depending on how they are feeling.
i know its a different product but a link g4 sells for an R34gtt and they plug straight into a C34 RS4-S (they market this fact aswell)
so i reckon a nistune in this instance might work.
however these are marketed for the series 2 rb25det NEO engine wont work with pre neo engine
Talking to my tuner about this months ago. Nistune will work in a s1 if you convert to manual. You can use the neo ecu on a s1 & s2 rb25.
I haven't been game to try the auto r34 ecu in my auto s1. I read some threads from years ago where the car would start and drive but would eventually die
It will work BUT if you use the wrong base image you are never sure what the factory ecu is doing behind the scenes. So in the case of running an R34 GT-t image you will throw a trouble code due to the lack of traction control. You can switch the notification off but it may be doing something in the background.
My RS4S was a pain in the arse on throttle recovery. It took me a long time figure (it went past 2 tuners as well) to notice that the base image was an auto image. I had the board re-imaged and I wish this had been done 2 years earlier...if it had been done right in the first place it would have made the car nicer to drive day to day in traffic.
well im looking at a bord from a MANUAL R34 GTT NEO into a MANUAL SII Stgagea rs4s NEO
the compatibility should be fine but i dont know if theire is other things on the ecu cuch as the 4wd which may get disturbed.
Again
4WD is not an issue AFAIK, more a case of whether the ECU is correcting the commanded values to protect itself.
The commanded values within Nistune for an R34 GT-t/RS4/RS4S look identical but some tables are not visible within Nistune so it isn't always easy to know if the output from the ecu isn't altered.
Keep in mind Nistune is a work in progress.
Edited by wolverine
It will be fine if you load up the right base image on the board whichever ECU.
It will probably be 99% fine as is...but it might give you a few niggling issues that $50 re-image will fix. Ask the guys at Nistune they are generally very helpful.
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
