Hi all,
cant find from searching,
will a Nistuned ecu from a manual R34gtt adapt into a C34 RS4-S stag?
appart from obviously needing to be retuned is there anything different which would stop this from working?
would i need to separate the board or could i swap over the ecu itself?
thanks for any help.
glyn.
https://www.sau.com.au/forums/topic/434143-r34gtt-nistune-rs4s/
You should be ok as all the maps and settings you can see are the same however the issue of traction control and what Nistune does with it might cause some background issues.
The board can have the correct base image loaded onto it by Nistune or some of the dealers with desoldering gear but that will cost around $50-75 depending on how they are feeling.
i know its a different product but a link g4 sells for an R34gtt and they plug straight into a C34 RS4-S (they market this fact aswell)
so i reckon a nistune in this instance might work.
however these are marketed for the series 2 rb25det NEO engine wont work with pre neo engine
Talking to my tuner about this months ago. Nistune will work in a s1 if you convert to manual. You can use the neo ecu on a s1 & s2 rb25.
I haven't been game to try the auto r34 ecu in my auto s1. I read some threads from years ago where the car would start and drive but would eventually die
It will work BUT if you use the wrong base image you are never sure what the factory ecu is doing behind the scenes. So in the case of running an R34 GT-t image you will throw a trouble code due to the lack of traction control. You can switch the notification off but it may be doing something in the background.
My RS4S was a pain in the arse on throttle recovery. It took me a long time figure (it went past 2 tuners as well) to notice that the base image was an auto image. I had the board re-imaged and I wish this had been done 2 years earlier...if it had been done right in the first place it would have made the car nicer to drive day to day in traffic.
well im looking at a bord from a MANUAL R34 GTT NEO into a MANUAL SII Stgagea rs4s NEO
the compatibility should be fine but i dont know if theire is other things on the ecu cuch as the 4wd which may get disturbed.
Again
4WD is not an issue AFAIK, more a case of whether the ECU is correcting the commanded values to protect itself.
The commanded values within Nistune for an R34 GT-t/RS4/RS4S look identical but some tables are not visible within Nistune so it isn't always easy to know if the output from the ecu isn't altered.
Keep in mind Nistune is a work in progress.
Edited by wolverine
It will be fine if you load up the right base image on the board whichever ECU.
It will probably be 99% fine as is...but it might give you a few niggling issues that $50 re-image will fix. Ask the guys at Nistune they are generally very helpful.
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
