Harro,
I have a split dump dump from 999 Automotive I want to sell, reason being it's about 1cm shorter than the stock one which causes my down pipe to touch the underside of my car. Having OCD, I don't like that so I've installed the stock one back again.
Same one as this, purchased from the same store. I have receipt which is included in the sale.
http://www.ebay.com.au/itm/KLS-EXHAUST-TURBO-twin-entry-DUMP-PIPE-NISSAN-SKYLINE-RB20-RB25-R32-R33-R34-/330890072292?pt=AU_Car_Parts_Accessories&hash=item4d0a95d0e4&_uhb=1
However, I've enlarged the holes to fit, removed the stupid divider (was hitting my wastegate flap).
So what you get is something that will fit straight up with out any mods, includes:
* Dump
* A bunch of bolts and washers
* No gaskets
* No divider piece (I chucked it out, on testing with an air compresser it hits that thing)
Save yourself some coin.
$50
Pickup from Canley Vale, NSW, 2166
Reply here or PM
Here are some photos...
I had to work this ling long piece of shit product to fit.
  • Hole have been enlarged
  • Casting marks smooth out with a flap disc
  • Divider removed
  • Proper fitting bolts purchased (nuts/studs provide did not fit)
Oh yeah, free working factory O2 sensor!
$T2eC16hHJIcFHOBy7VepBSeNsI5sBw~~60_58.J
$(KGrHqVHJBMFJipNVsodBSeNupU3bw~~60_58.J
$T2eC16ZHJH8FHQqI,,h,BSeNwdl1Hg~~60_58.J
I had the same thing, my down pipe from them was about 2 to 3 inches short, I had to cut in and weld in a section to lengthen it, had no choice. Good luck with the sale mate
or use a spacer/flange to make it longer...
I'm going v band next so no need for this ling long bullshit lol
Free for me?
for a slab of blonde and I ain't fitting it... I don't want to snap dump bolts (always happens) lol
Just playin. Ain't no body got time for ling long shit!
hahahah that's right!
Unless you're not anal like me, I hate shit that doesn't fit.. gets on my nerves
  • Like 1
  • 3 weeks later...
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
