Hey guys selling my gas stag regretfully
97 s1 stagea
car is comfy and is a very practical import with skyline performance.
It has:
R33 gtr gearbox clutch less than 1yr old
S14 lsd diff
Custom tailshaft
Gas research lpg system
Garrett gt2528rs turbo
Aluminum radiator
Thermo fan
Front mount intercooler
R33 front brakes
Apexi safc
Coilovers all round
160kms
Good condition R32 gtr wheels with good tread
Towbar
Made 190kws @ wheels on 13psi
Was planning on building a rb25/30 for the car and hav a nice rb30 ready for it...just last week piston 1 dropped compression. I dont have the time or space to do wat I planned for it and sadly has to go...has been my everyday driver and hasnt let me down.. its cheap to run and runs better on gas!!!
Comes with 160psi all cylinder good runner rb30 engine ready for swap or a rb25 can be had for 1k just swap the parts over.
And quite a few spares if the price is good
The car is still complete and registered even drives well still and all great besides motor. My loss is ur gain..
Im after $4500 which is less than wat ive spent on the mods done
got different rims if u wanna drop price
Located in northern suburbs melbourne
Thanks rob
0403 107 513post-46448-0-82199700-1382951051_thumb.jpgpost-46448-0-50300300-1382951033_thumb.jpgpost-46448-0-46369400-1382950993_thumb.jpgpost-46448-0-52336800-1382950947_thumb.jpgpost-46448-0-48110000-1382949106_thumb.jpg
Edited by nisrob
https://www.sau.com.au/forums/topic/434179-s1-stagea-manual-lpg-melb/
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
