Hey all,
Looking at some Varrstoen es1 rims (BBS LM replicas) for my gtt, but I can't decide whether I want 18's or 19's.
My current setup is 18x9.5 +15 all round, with 255/35. The fronts sit pretty close to flush, while the rear guards definitely have room to accommodate a wider rim and tire.
**The most aggressive setup offered in 18's are: 18x10.5 +12
These will sit 16mm further out than current rims, with the inset having 10mm less clearance. (basically around 5mm poke at the front, rear's pretty flush I'd assume)
**The most aggressive setup offered in 19's are: 19x11 +12
These will sit 22mm further out than current rims, with the inset having 16mm less clearance. (around 11mm poke at the front, slight poke at the rear)
Seeing as the rims have a step lip, this usually makes them appear smaller, which is my argument for going with 19's, but that said I wouldn't be able to lower the car any more, and I think they will foul on the coilovers.
18's allow me to lower the car slightly to eliminate wheel to guard gap, and I'm a bit more confident on this fitment clearing everything.
OPINIONS AND COMMENTS!
https://www.sau.com.au/forums/topic/434208-18-or-19-inch-rims-on-r34-gtt/
I would go 18's on a GTT, 19's will be too hard to fit, The right rim will look nice whether it is 18 or 19.
You were the one with pumped guards yes? If the most aggressive offset isn't enough poke for you I would just run a hubcentric spacer, it will only be ~10mm anyway?
Yep, pumped rears, gtr fronts.
I've been thinking 18x10.5 +12 with a 265-275/35 on the rear. I'm sure this will look fine, but yeah if needed I'll run a bolt on.
Fronts will need some camber if I go a 265/35.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
