Hey all,
Looking at some Varrstoen es1 rims (BBS LM replicas) for my gtt, but I can't decide whether I want 18's or 19's.
My current setup is 18x9.5 +15 all round, with 255/35. The fronts sit pretty close to flush, while the rear guards definitely have room to accommodate a wider rim and tire.
**The most aggressive setup offered in 18's are: 18x10.5 +12
These will sit 16mm further out than current rims, with the inset having 10mm less clearance. (basically around 5mm poke at the front, rear's pretty flush I'd assume)
**The most aggressive setup offered in 19's are: 19x11 +12
These will sit 22mm further out than current rims, with the inset having 16mm less clearance. (around 11mm poke at the front, slight poke at the rear)
Seeing as the rims have a step lip, this usually makes them appear smaller, which is my argument for going with 19's, but that said I wouldn't be able to lower the car any more, and I think they will foul on the coilovers.
18's allow me to lower the car slightly to eliminate wheel to guard gap, and I'm a bit more confident on this fitment clearing everything.
OPINIONS AND COMMENTS!
https://www.sau.com.au/forums/topic/434208-18-or-19-inch-rims-on-r34-gtt/
I would go 18's on a GTT, 19's will be too hard to fit, The right rim will look nice whether it is 18 or 19.
You were the one with pumped guards yes? If the most aggressive offset isn't enough poke for you I would just run a hubcentric spacer, it will only be ~10mm anyway?
Yep, pumped rears, gtr fronts.
I've been thinking 18x10.5 +12 with a 265-275/35 on the rear. I'm sure this will look fine, but yeah if needed I'll run a bolt on.
Fronts will need some camber if I go a 265/35.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
