Im thinking of selling my 1995 r33gtr,non vspec.I purchased the car of Adam Neish of JEM fame.I purchased the car in early august with a view to do an occasional track day and weekend car.Due to a new house purchase I will be going to a property with a double garage,and thinking of selling this vehicle and my daily ride and going back to one car.
About the car,it is very clean silver vehicle,with carbon fibre wing insert,tinted windows,led taillights,clean xenon headlights.It is rolling on rare Rays SE37s in black,with brand new 265/352/18s federal rs-r semi slicks.Lowered with aftermarket springs and bilstein shocks,and various aftermarket bushes.
Standard bottom end,relocated oil filter,large greedy fdront mount and piping,750cc injs,turbosmart fuel reg,044 intank,quality high mount steam pipe manifold with Precision 6266 turbo,,unknown brand smallish cams,3'' manderal bent exhaust,ballistic 100cpi cat leading into nismo muffler with carbon tip.Haltech platinum pro looks after the tune.As you would expect the tune is absolutely spot on.
5 speed box is nice to use with heavy duty clutch.
Inside,very clean gtr interior with white face nismo dash and centre gauges,hks pillar mounted boost guage,blitz electronic boost control and blitz turbo timer.Aftermarket cd stereo with removable sub.
Have the dyno sheet,on low boost 18 psi 333.1kws at all 4 wheels and on 20psi tapering off to 19psi it makes 343kws or 460 hp.Adam has done a very safe tune and believes at this tune will last.
I have never taracked it but did race it once at wsid after having the car for 2 days,not knowing how to launch a 4wd car it ran 11.9 @ 119mph.with a slow 60ft time,should run 11.5s with a decent driver.
I do have brand new for it a set of 1000cc injs,arp head studs and walbro 460l/ph pump.We were going to do a e85 tune and shoot for 400kws at the wheels,but deceided not too.
Im looking for $22,500 for the car,and $23,000 with all the other bits injs,studs and pump.My number is 0410993105,and I will try and load some photos later on.
https://www.sau.com.au/forums/topic/434211-eoi-1995-r33-gtr460hpex-jem-car/
post-117676-0-31312500-1383732344_thumb.jpgpost-117676-0-15140200-1383732380_thumb.jpgpost-117676-0-15619900-1383732403_thumb.jpgHave just listed the car on ebay and will also do carsales,some more pics.Have just done a carbon wrap bonet using avery Denison vinyl,can be removed.Listed it for $21,000,still hoping to get up near $22,500 with some extras,and some more pics.Call 0410993105
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
