I'm looking for a new set of track pads to replace my DS2500s. The DS2500s were nice, but might get me through 2.5-3 track days.
I'm interested in anything similar that might last a bit longer or doesn't cost as much to replace every half handful of track days. Happy for them to be a track only pad and to be swapped out for any street/hill climb/deca stuff.
Have been looking at others like DS3000s, Hawk DTC-60, QFM A1RM. I know the DS3000 and DTC-60s aren't cheaper in many cases, but maybe they will last a bit longer.
Any feedback is appreciated!
https://www.sau.com.au/forums/topic/434224-track-pads/
Pagid RS19s are nothing like DS2500s though. Endless CCRG are race pads! The Club Racer are much bitier then DS2500s from what I could feel in the car I have driven with them (WRX so pretty boig variable there). All the suggested pads are damn good pads but bite, temp range and price all very different to DS2500s.
My guess again is if you like DS2500s then stay away from Hawk which generally have a lot more bitet then the more wooden DS2500s. QFM A1RM are a decent enough pad but like the RB74 and others I think you will find they wear just as fast, if not faster than DS2500s.
If you like the feel and lack of too much bite of the DS2500s then consider something like a Pagid RS4-2 pads. They are a nice pad that are not too bitey (for those without ABS) and last a life time...good on rotor wear as well
https://www.sau.com.au/forums/topic/434224-track-pads/#findComment-7086360
A1RM's are not recommended for pure track pads, have just got some Carbotech XP10's from the US but have not tried them yet.
I run them as such, and they are fine for me. Nil fade or overheats. Difference is its a 180sx that's stripped, and has 324mm front 297mm rear discs.
3 track days in on them, and I'd be comfortable doing another two before changing the front pads.
https://www.sau.com.au/forums/topic/434224-track-pads/#findComment-7086939
I've used A1RM's too but they are not a race pad, same with the Lucas TRW pads now being used and which are going to be replaced with the XP10's.
https://www.sau.com.au/forums/topic/434224-track-pads/#findComment-7087150
  • 1 year later...
Old thread bump.
Any updates guys?
Emo is getting low on pads, so looking for options.
Also, road/track day rotors.
Or should I look for a separate thread?
I has option for you ;)
Dba4000 work well and emo being 2piece should have replacement rings??
https://www.sau.com.au/forums/topic/434224-track-pads/#findComment-7484601
  • 1 year later...
Bit of a bump here, looking for experiences with various track only pads. My present Carbotech XP10's are bloody brilliant, great bite feel and modulation and stand the car on it's nose retardation, kind to rotors too. Only problem is that they wear quickly compared with a good street pad and have to be US sourced. Which is not as cost effective as it used to be.
So, any recommendations other than Hawks and Ferodos?
https://www.sau.com.au/forums/topic/434224-track-pads/#findComment-7714617
Go to Race Brakes and get a set made up to your requirements
https://www.sau.com.au/forums/topic/434224-track-pads/#findComment-7714624
Intima SR pads - very good pads for sprints and track days. Excellent value, they are rated to 650 degrees and were kind to my DBA rotors.
I got around 4-5 events out of them. Car is an S13 Silvia, 1070kg and 230kw's@wheels.
I recently upgraded to the Type D pads which are rated to 850 degrees. After switching to E85 and retune up to 255kw's@wheels I was thinking I might be arriving at corners a little quicker now and thought I'd go the more aggressive pad.
The Type D pads were $200 for the front pair.
https://www.sau.com.au/forums/topic/434224-track-pads/#findComment-7715022
Will check out the Intima pads, has anyone tried the Project Mu Club Racer pads? They are available in stock locally.
The club racer had to much bite for me. So I've been using the hc800 since WTAC last year. They are lasting pretty well. Good progressive bite, but they do fade off on my 330mm rotor. Which is more disk heat related than pad I think.
https://www.sau.com.au/forums/topic/434224-track-pads/#findComment-7715104
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
