Track Pads
I'm looking for a new set of track pads to replace my DS2500s. The DS2500s were nice, but might get me through 2.5-3 track days.
I'm interested in anything similar that might last a bit longer or doesn't cost as much to replace every half handful of track days. Happy for them to be a track only pad and to be swapped out for any street/hill climb/deca stuff.
Have been looking at others like DS3000s, Hawk DTC-60, QFM A1RM. I know the DS3000 and DTC-60s aren't cheaper in many cases, but maybe they will last a bit longer.
Any feedback is appreciated!
Pagid RS19s are nothing like DS2500s though. Endless CCRG are race pads! The Club Racer are much bitier then DS2500s from what I could feel in the car I have driven with them (WRX so pretty boig variable there). All the suggested pads are damn good pads but bite, temp range and price all very different to DS2500s.
My guess again is if you like DS2500s then stay away from Hawk which generally have a lot more bitet then the more wooden DS2500s. QFM A1RM are a decent enough pad but like the RB74 and others I think you will find they wear just as fast, if not faster than DS2500s.
If you like the feel and lack of too much bite of the DS2500s then consider something like a Pagid RS4-2 pads. They are a nice pad that are not too bitey (for those without ABS) and last a life time...good on rotor wear as well
A1RM's are not recommended for pure track pads, have just got some Carbotech XP10's from the US but have not tried them yet.
I run them as such, and they are fine for me. Nil fade or overheats. Difference is its a 180sx that's stripped, and has 324mm front 297mm rear discs.
3 track days in on them, and I'd be comfortable doing another two before changing the front pads.
I've used A1RM's too but they are not a race pad, same with the Lucas TRW pads now being used and which are going to be replaced with the XP10's.
  • 1 year later...
Old thread bump.
Any updates guys?
Emo is getting low on pads, so looking for options.
Also, road/track day rotors.
Or should I look for a separate thread?
I has option for you ;)
Dba4000 work well and emo being 2piece should have replacement rings??
  • 1 year later...
Bit of a bump here, looking for experiences with various track only pads. My present Carbotech XP10's are bloody brilliant, great bite feel and modulation and stand the car on it's nose retardation, kind to rotors too. Only problem is that they wear quickly compared with a good street pad and have to be US sourced. Which is not as cost effective as it used to be.
So, any recommendations other than Hawks and Ferodos?
Go to Race Brakes and get a set made up to your requirements
Intima SR pads - very good pads for sprints and track days. Excellent value, they are rated to 650 degrees and were kind to my DBA rotors.
I got around 4-5 events out of them. Car is an S13 Silvia, 1070kg and 230kw's@wheels.
I recently upgraded to the Type D pads which are rated to 850 degrees. After switching to E85 and retune up to 255kw's@wheels I was thinking I might be arriving at corners a little quicker now and thought I'd go the more aggressive pad.
The Type D pads were $200 for the front pair.
Will check out the Intima pads, has anyone tried the Project Mu Club Racer pads? They are available in stock locally.
The club racer had to much bite for me. So I've been using the hc800 since WTAC last year. They are lasting pretty well. Good progressive bite, but they do fade off on my 330mm rotor. Which is more disk heat related than pad I think.
 Share
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
