Hi All,
Below a list of all stuff that was extracted out my 1999 R34 GT-R V-Spec as it got modified:
Motor/Driveline:
- Complete R34 GT-R twin turbo setup (includes turbos x 2, housing x 2, manifold & turbo dump x 2, actuators x 2, lines, hoses, flanges, screws, bolts, nuts) $600
- Standard R34 GT-R 'Nismo' Intercooler x 2 $120 each
- Standard R34 GT-R Ecu (plug and play) - R34 GT-R Exclusive I think (could be wrong) - expressions of interest
- ARC (very rare and 'classy' brand) Enclosed Pod Filter with AFM's and Induction Pipe(s) - includes the Genuine twin turbo pipe $600
- Standard twin BOV's with mounting pipe $195
- JASMA approved FULL exhaust setup (includes Genuine Trust Front Pipe mounted on), catless then tip (can get you the specs of the exhaust, eg: input/output inch's) $960
- Genuine R34 GT-R water pump $80
- Genuine R34 GT-R radiator $195
- Genuine standard R34 GT-R (can be used on other GT'R's): IN and EX Camshafts $250 set
- Genuine standard R34 GT-R (can be used on other GT'R's): IN and EX Cam gears $150 set
- Standard R34 GT-R fuel rail with standard regulator $130
- Standard R34 GT-R injectors (x 6) and supporting lines/adapters $100
- Genuine RB26 Red Top Cam Gear/Timing Belt Cover $70
- Standard R34 GT-R Front Pipe (twin setup) $165
Suspension/Exterior:
- Standard/Genuine R34 GT-R V-Spec, front (x2) and rear (x2) coilovers $450 set
All parts in working condition.
Contact Faiz on 0422 726 309. Flexible with prices depending on the mood :)
Thanks.
  • 3 months later...
Hi All,
REVISED
Motor/Driveline:
- Complete R34 GT-R twin turbo setup (includes turbos x 2, housing x 2, manifold & turbo dump x 2, actuators x 2, lines, hoses, flanges, screws, bolts, nuts)$600
(I/C with temp sensor $200; I/C without temp sensor $170)
SOLD
- Standard R34 GT-R injectors (x 6) and supporting lines/adapters $140
SOLD
Thanks.
Hey bud.
It is not a Z-Tune Factory "NISMO" Intercooler.
It is a factory 1999.3 BNR34 V-Spec Intercooler with no writing on it.
A quick pic attached below.
Edited by fujin
  • 3 weeks later...
REVISED
Motor/Driveline:
SOLD)
- ARC (very rare and 'classy' brand) Enclosed Rectangle 'Box' Pod Filter with AFM's and Induction Pipe(s) - includes the Genuine twin turbo pipe $600
- Genuine R34 GT-R water pump $80 SOLD
- Genuine R34 GT-R radiator $195 SOLD
- Standard R34 GT-R injectors (x 6) and supporting lines/adapters $150
(The injectors are currently mounted on the standard fuel rail, so $280 combined)
SOLD
Thanks.
  • 3 months later...
REVISED (as at July 2014)
Motor/Driveline:
- Standard R34 GT-R Intercooler
$200 PENDING PAYMENT
SOLD
SOLD
Thanks.
Interested in the exhaust if its 3.5 inches.
if you could get a pic of it that would help.
thanks
Hey bud,
My old exhaust setup was sitting at the workshop, let me find out about its whereabouts.
It was 2.75inch (twin turbo frontpipe TRUST) to 3/3.5inch catback.
Happen to have exhaust temp sensor by any chance?
No bud, I am currently using the exhaust temp sensor on my current manifold/exhaust setup.
Latest Pic's of the Standard BNR34 (V-Spec) FMIC for Sale:
A few array of fins are evidently curved/bent (on the front face of the FMIC), but this very FMIC was able to safely hold 400kwatw.
keen on the exhaust, any pics available?
My old exhaust setup is sitting at the workshop, let me locate it and post the details accordingly.
Thanks.
Edited by fujin
Guys, an update on the exhaust setup.
It's nowhere to be found which means its been sold or given away previously.
Sorry for the suspense.
Thanks.
REVISED (as at 25 July 2014)
Motor/Driveline:
SOLD
SOLD
Thanks.
    • The interesting part of tests like IM240 is they measure the exhaust output. But they never measure the gases going into the engine... Imagine doing the test in a densely populated city with higher CO2 levels around... Instant disadvantage...
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
