I just had a look through the entries - is there any reason in particular that so many fast SA Skylines are not running at the Nationals? There are far more entries from Vic than SA - very perplexing.
If you have not entered yet, entries are nearly full and there are only days left.
Get on it.
http://www.skylinesaustralia.com/forums/topic/431690-2013-track-day-entry/#entry7014975
Get on it.
Im doing my hair that weekend, sorry :P
Oh, you said fast didnt you
/hides in the corner
Just throwing it out there but this also falls on the same weekend as the schoolies festival.
I'd very much like to do the car show but living at Victor Harbor I dont exactly want to take my car out that weekend.
What happened to your old one Matt? :(
It wasn't powerful enough :D So I decided to step up to a RB25/30 with E85 specific compression in mind, and a nice little FP HTA GT3586R hanging off the side.
You can leave it at my place if you want for a few days.
My car won't be complete due to my injuries, and i cant see myself even going at this rate. Really quite frustrating.
If i can get healed up in time does any one mind taking me to the show n shine? I'm not insured to drive at the moment.
where is this taking place??
Friday at Mallala (race track)
Saturday at Collingrove Hillclimb (near Angaston in the Barossa)
Saturday night at Mawson Lakes
Sunday at Glenelg
Full details are at http://www.saunationals.com/event_info_entry.php
Is there a cut-off date? Couldn't see one. My Car goes in for new turbo combo/tuning on Monday, waiting to see what the aftermath of it is.....
You big girl. :nyaanyaa:
  • Like 1
Spectators - 100% will not be charging for spectators. It's a club level event, pits are fully open etc.
I don't know how other clubs/events think that's remotely fair to charge. So come/go as you please on all days!
There is - It was today, however there have been a couple track day pull outs. So will leave it open till COB Monday.
Dinner - it's a full sit down dinner, raffle prizes you get buy a ticket for etc. Great Value for $40 entry really pretty sure over 100 people already in :)
The Vic crew are getting set and ready, some spent the weekends on their cars and ready to fly the flag :thumbsup:
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
