Hey guys,
Spent the last 3 months doing a few things to my rb25det and it just died in the ass today. 6th cylinder is letting oil by the piston rings and i think it sounds like it is developing some nasty piston slap!
My list of works completed:
- Reconditioned head, replaced valve seals and replaced valve springs with Supatech valve springs.
- Installed Cometic MLS Headgasket and ARP head studs.
- Installed 256 Camtech cam shafts and 2 adjustable tomei cam gears.
- Rebuilt my turbo at GCG and got it high flowed (stage 2 - with ball bearings, rated @500hp).
- Installed Five-O 660cc injectors (red plug).
- Replaced all gaskets for the top end of the motor.
- Installed JJR Bellmouth dump pipe.
I put it all back together and was able to tune the car upto 8.2 psi and got a nice 184rwkw before all the fun was over.
Even though it didn't work out the best I still had a lot of fun putting it all together and going through the whole project.
What you guys think I should do? Give in and sell it? Rebuild the bottom end? Or just buy a replacement bottom end of a second hand motor?
Ps: thanks to anybody who helped me and answered my questions on this forum - have to admit I did a lot of reading here and learnt a lot about my car!
https://www.sau.com.au/forums/topic/434278-mini-overhaul-of-my-r33-gone-wrong/
seems like you have kesh......
go forged and stroked rb 30 bottom end. bolt all your shit up and see what you get. then change parts as they start limiting you!
Hahaha let's just say I had cash!
That would cost me like 15k :(
cheapest and easiest option. just get a second hand motor, plenty of guys running 300rwkw+ on standard motors.
if you have the time id pull the engine out and see whats gone wrong.
I was thinking along the lines of getting a replacement bottom end and throwing it in... Just worried about the quality of wreckers.
Wish I had the time right now to rip it apart and see the damage!
buy another stock bottom end for couple of hundred bucks e85 these days 350kw is safe with it no need to waste money building.
Exactly what I was thinking but here's the issue - who's gunna split their perfectly fine motor to give you a bottom end.
Buy a complete running engine, there will be heaps available. This way you aren't up for a top overhaul gasket set and you can do compression/leak down tests. You can't do that with just a bottom end and some questionable build story.
Might give it a try - found an engine for 950$. Hope I don't spend another 2 months doing this for no good result :)
what was the compression of the motor you bought?
It was the motor in my car - did a compression test last Sept and had decent results (can't remember exact numbers). The reason it buckled is because it misfired as a result of bad coil packs... Even though I got the misfire fixed, the damage to the motor was already done.
+1 second hand/import motor, not 2 months, chuck it in this weekend :P , plus might be hard to get a tune around xmas
I wish I could afford it to be honest - need to work atleast 2-3 weeks before I have another crack at it!
faaark!!...all that work for 184kws...i think i would of set fire to it there and then....I put a 5$ bleed tap from bunnings on my stock car with an exhaust and it made 185kw...
what computer you running?
I think you may have misread my post - the engine shat itself and the best reading I received was 184rwkw at 8.2psi. I was planning on running it at 20psi which would of given me roughly 300rwkw. :)
My car now runs at 0rwkw and pours out an awesome smoke show from the tail pipe ;).
PS: Running a microtech.
I just realised - I originally made that post on Tapatalk with paragraphing (and bullets) and when I looked at it on the PC it looks like one massive blob of a post with no structure... thats odd :(
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
