Wrecking r34 gtt coupe no gearbox or engine
R34 gtt coupe rolling shell
No interior no engine bay stuff no front end panels
Comes with complete rear end brakes all round etc has boot rear bar doors. Can be regoed I have a brand new rad support for it for extra clean and straight
$2500
R34 xenon headlights absolute mint condition $800
R34 xenon headlights missing few tabs not best of condition suit track car $200
R34 gt bonnet $250
R34 gt front bar with Reo $300
R34 front passenger Gaurd $70
R34 front drivers Gaurd $70
R34 door cards $100 pair
R34 drivers window motor $90
R34 passenger window motor $50
R34 manual speedo cluster $80
R34 top centre gauges and pod $100
R34 window switch drivers side $70
R34 gtt front seats pair $200
R34 rear seat $100
R34 manual gear boot and surround $130
R34 centre console $70
R34 dash $100
R34 boot trim and carpets $100
R34 gtt tailshaft complete $100
R34 gtt clutch pedal $60
R34 gtt brake pedal $50
R34 gtt master cylinder $60
R34 gtt brake master and booster $50
R34 gtt neo engine loom $150
R34 gtt manual neo Ecu $100
R34 abs module $80
R34 gtt radiator $60
Rb25det neo alternator $50
Rb25det neo power steer pump $70
Rb25det neo air con pump $60
R34 gt strut brace $40
R34 washer bottle $40
R34 overflow $40
R34 gtt gearbox shifter $60
May have missed stuff
Located on the Gold Coast
0487924497
can you please send pics of the R34 xenon headlights missing few tabs not best of condition suit track car $200 to kirasuran@ gmail. com thanks! and how much postage to sydney 2052?
  • 3 weeks later...
  • 1 month later...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
