Hi all,
The time has come to part ways with my GT-R. I hardly ever get to drive it (ride my bike to work), and would rather send it on to someone who'll appreciate it. (Seriously, I've done 25,000kms since importing it 5 years ago!)
It's just had a professional respray, as the paint was looking a little worn after 21 years. I had both windscreens, and the Qtr glass out (wanted to make sure no there was no rust lurking unseen). New genuine seals and stripping used when they were re-installed (have receipts).
I have also replaced with brand new B-C pillars trims. If you own an R32, you'll know how fragile these get.
Other goodies include:
Apexi PowerFC, hand controller and Apexi Boost Controller
Apexi Pod filters with 80mm AFM's
Tein coilovers
Hasemi 3-piece 17" lightweight race rims (made under licence by SSR) with new rear tyres and near new fronts
Raizen Voltage stabiliser and earth kit.
Mine's 320km/h ECU
52mm alloy radiator
Tanabe HyperMedallion cat back exhaust (I think it's 3")
ORC 709 Twinplate Clutch
I've also replaced the following items:
New genuine Slave Cylinder
New genuine coolant and air hoses
New genuine rocker cover gaskets (old rubber goes hard)
New CV Boots and tie rod ends
New genuine N1 Grille
New JJR N1 Bootlip (original had distorted)
Bad Points:
Drivers side seat bolster is torn/worn
Drivers vinyl trim on door is cracked (could be fixed with one of those Ebay trim kits)
Screw holes on A pillar and centre trim surround
Other minor wear and tear
No Ash tray or lighter (gauges were fitted when I bought the car)
I've also got the following spares which the new owner can have if they want them:
Spare dash (has bubbles, but could be used for reupholstery)
Spare standard head lights (currently has N1's fitted)
Standard Airbox
Oil filter relocation kit and oil cooler with lines
Oil pressure and temperature guages (fit into the relocation kit)
Water temp gauge
Have all the importation/compliance paperwork as well.
So really, a lot of monster for the asking price.
Price is negotiable, but please don't low ball.
post-45599-0-21776300-1383184286_thumb.jpgpost-45599-0-12972000-1383184287_thumb.jpgpost-45599-0-34226300-1383184288_thumb.jpgpost-45599-0-73574600-1383184289_thumb.jpgpost-45599-0-11687100-1383184290_thumb.jpgpost-45599-0-83142600-1383184290_thumb.jpgpost-45599-0-15656600-1383184305_thumb.jpgpost-45599-0-09092400-1383184306_thumb.jpgpost-45599-0-05892600-1383184307_thumb.jpgpost-45599-0-40394900-1383184308_thumb.jpgpost-45599-0-71955300-1383184308_thumb.jpgpost-45599-0-09232600-1383184309_thumb.jpgpost-45599-0-64138000-1383184309_thumb.jpg
  • 1 month later...
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
