3x S14 manual gearbox Xmembers.$50 each
R33 rotors and calipers $400
s13 and r33 interior plastics, prices depending on what bit you're after.
R33 doors , L and R, $100 each including door cards and switches
S15 drivers guard $100
R33 front guards, Red ones $80, black ones $100
R34 rb25 block, under 80,000ks on it, rest of engine got parted out $200
R34 rb25 crank $100 no journal damage
New Rb25 sump, never been fitted, no scratches $100
2nd hand rb25 sump, $50
various radius rods(caster rods) let me know what measurement you want and ill see if i have some(i have a milk crate full of them for some reason) All appear to have good bushes in them $25 a pair
R33 caster rod brackets $50 the pair
r33 cross member, drops your rb lower than cefiro or r32 xmember does. $100
R33 lca's $150
S13 digital dash cluster $50
S15 JDM drivers side tail light $50
R33 tail lights $50 a side.
S13 bonnet (black) $80
R33 rear bumper $50
S13 rear bumper $50
S13 veilside rear bumper $50
S13 front bumper $50
S13 front reo, undamaged, uncut $150
will post up more as I remember what I've got...
come get it yourself, I'm not stuffing about posting things.
Located towards Ipswich. Pics available as reqiured
https://www.sau.com.au/forums/topic/434361-r33-s13-and-s15-bits-and-pieces/
  • 1 month later...
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
