I have a manual r34 turbo box for sale.
Its in good clean condition and was going to go into my RWD rb26 build.
Why am I selling? Have gone rb26/30 which needs a 33 box.
ASKING PRICE $1,400
LOCATED IN MELBOURNE - NEAR CHADSTONE
As part of a package deal only! might consider including flywheel, aftermarket clutch, starter motor, plate & 2x brackets.
Edited by pauls
https://www.sau.com.au/forums/topic/434367-r34-rb25-manual-gearbox/
Apparently bell housing on 33 & 34 are different.
Plus one is pull other is push.
Thanks but purchased motor & 33 box combo.
Thus I now have a spare box r34 box
Edited by pauls
  • 4 weeks later...
  • 3 weeks later...
did I mention $1,300 was cheap for an r34 manual gearbox?
in storage for a while so hasnt been clocking up k's nor is it out of a smashed car..
Edited by pauls
  • 3 weeks later...
  • 3 weeks later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
