Hey guys, didn't know where else to post this.
Anyone here familiar with systems that can be installed for homes that have say 4 wireless cameras connected to something that shows them all onto a monitor and can record them all onto a hard drive?
Any suggestions on products or where i can buy good quality products?
Or if you are an expert and have experience installing them i would like to hear from you as well! (Will be getting something for my house very soon).
Cheers!
https://www.sau.com.au/forums/topic/434400-wireless-home-security-cctv/
I bought a couple of the basic wireless Swann units. They're very consumer focused (ie. simple to install and operate). They'd be no good for what you're after though. You can view them from your IOS or Android phone easily using the App. The sucky side is that there is no method to record anything to harddrive and they're pretty much trying to sell you a monthly recurring fee to use their 'cloud-based' motion recording system. You get a free trial for 30 days and as much as it works well - I hate lock-in recurring fees.
Edited by epoq
Ive installed cctv wireless systems jnto workshops and homes, id definitely say go wired, more reliable, no wireless issues but is more expensive to install...
Basically the more the you pay the better you get. Wired is the way to go, if you look at the high end systems they are all hard wired, in saying that though i have clients with wireless with access from iphone and it works ok...
Also look at the lens on the cameras as some have a wider view than others, so if the camera is mounted like 6m away from target youll need a view to be able to make it cover the most area
try using D-Link products, simple as bat shit to set up and buy like a Synology NAS to do all the recording...
alternatively you could build a PC specifically for recording all the wireless D-Link cameras, just pop in RAID1 with 2x 3TB NAS HDDs and a high effciency PSU and off you go.
I'm currently using a D-Link wireless 932L camera, works a treat.. automatic day/night with sound. I can remote into it from my phone and see/listen to what's going on and my Synology DS-212 NAS records everything
Thanks for the tips mate, definately keen to get wired installed, but in a 2 storey house i hear its going to be uber expensive.
I have thought about that, i have a server running freenas but i need external cameras and if they need power + ethernet, its pretty much the same thing to get installed lol.
Thanks guys, still looking but :D
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
