I'm curious if it's worth swapping the os giken close gear as a performance improvement mod ? Could it help make the car feel more responsive ? Most people talk about it as a upgrade after breaking the gearbox oem. I'm more curious about the performance mod of this close gear set. Who tried it back and forth? what is your thought on how it drive ?
I have one and looks like I busted it on Tuesday.
If its a road car YOU MUST HAVE a decent curve otherwise the car will be a nugget. With a nice flat "torquey" curve, it's a great thing.
I swapped between OS and standard numorios times until OS was smashed beyond repair. With stroker and single turbo, once underway it's awesome. But getting off the line in a hurry can be all or nothing due to long first. I did like it tho, you definately notice the difference.
What did you do after the OS was busted?
Yeah Joey just put the box in last week and all seems good. Will give it proper test this Thursday ( rally sprint). Not sure what to report unless it breaks.
So Piggaz I'm trying a standard gearset cryoed with billet centre plate. If that fails, not sure what I'll do?
I Guess theres no real way to know unless it does break lol, how much power is getting put through this transmission?
what clutch and tyre set up is being used?
thanks
About 600rwhp, semi slicks at the track and a gearbox munching OS Giken R3C triple plate. Which I hope to replace with Nismo copper mix before it takes this box out. Altho I looked at it the other day whilst box was out and after about 40k kms, hundreds of launches and half dozen gearboxes it doesn't look like wearing out any time soon.
good to know, this is approximately the power ill be making and im also using a copper mix... will be very interesting to see how this goes
I was having a think about this lately as my second gearbox is rattling around a bit. I was thinking going shorter diff gears and maybe seeing if I could keep the stock 1-4 gears and going a longer 5th for cruising. Also triple plate clutches or high clamping force singles smash boxes so a nismo or the new organic twin plates seem to be more forgiving.
Maybe an option to consider rather than a close ratio gearbox.
That R3C thing is one hardcore clutch.
The Nismo will an awesome "upgrade" and definitely help with boxes staying together.
so hardcore it left impressions on the input shaft.
I'll get a picture with both plates to show how much flex has been taken out of the system.
That would make 1st crazy short
Yeah but I think the op is wanting response, so I assume he is talking about 2nd to 4th gear more than anything. And it would help keep the -5 on song especially in the tight stuff where you can't grab 1 but would like to.
i could be thinking about this all wrong.. but wouldn't that just shorten all the gears by the same amount and not actually make the gap between gears closer, therefore not making a closer ratio ?
Edited by tricstar
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
    • If you want the screaming "weeeee" sound, just let the gasket between the exhaust manifold and the turbo break a little. It'll go "weeeeeeeeeeeeeeeeeeeeeee" everytime its on boost...
