Hi Everyone,
I'm relocating from SA to Springfield Lakes. Can you help me with a suggestion of where I should go for a RWC and mod plate?
In another thread I was told my car looked low and that the cops would pull me up straight away. I believe my car is standard height and it's the illusion of the kit that give it the appearance of being low.
Here are the photos I took for the transport company
I can get 2 fingers in between the tires and guard front and rear. Is it too low?
Any help would be appreciated.
Cheers.
space between guards and tyres is not an issue, as long as the lowest point of your car (including the exhaust just near the diff) is above 100mm
What parts of the car need to be mod plated?
Everything is above 100mm (when checked on level ground)
I have no idea what needs mod plating (because I'm not familiar with your regulations)
My list of mod are:
Secured Apexi pod (not in a box)
z32 AFM
hard suction kit
T04 Turbo
Stainless ext. manifold
Turbo back ext. with hi flow cat etc. Not loud
Manual boost controller (22psi)
FMIC (metal was cut to accommodate the piping to the throttle body)
After market BOV that is 100% recirculating
Q45 Throttle body
Freddy forward facing intake manifold
1000cc injectors
Top feed fuel rail
Turbo smart FPR
Walbro pump
RB20DET ECU with nistune, running E85
permanent wideband lambda, boost, temp gauges to DLP-I08 and Consult
I think that's about it
You will need a mod plate for the turbo at the very least and the hole for the FMIC will probably need to be certed as well, as for the rest I'm not sure. The reo being cut will be a defect if it is found and can't be mod plated.
I know of a mobile mod plate guy on the northside but I'm not sure how far he roams to plate cars. As everyone said keep your SA rego until you have everything up to scratch.
