Hi Guys,
A bit of a rookie question but thought I would ask here before I do anything I regret. I'm just wondering where the best place to put my jack stands would be as I need to get under the car to do a bit of work and don't want to rely on a jack alone. I've taken a look around and I can't seem to find any definitive answer so just asking here instead.
This is currently where I'm jacking the car up from:
http://imgur.com/J8MgZWu
And am now unsure where to place the jack stands, I was thinking in this area here:
http://imgur.com/YwbQOz6
And to zoom in a bit more I was then thinking about placing them on this little ledge (just to the left of the red line), would this be ok? It's at the start of two beams which run down the length of the car but I don't think those beams themselves are strong enough to hold any weight as they do seem a bit soft.
http://imgur.com/0LE7OwN
Cheers for any help in advance
Edited by pdot
Those beams are not strong enough to jack or put stands under, they will crush and make your car unroadworthy.
Always use the sill jack points or the crossmember under the engine.
Here's the recommended lift points, but take care.
These are designed for an even lift, something like a 4-point hoist.
If you intend jacking up from a cross member and then transferring to these jack points via stands, you won't achieve the even loading that a hoist can.
You'll find one stand will take a lot of weight before the other touches.
I use the front tow hook and rear diff as jacking points. Haven't had any issues and it's on stands regularly.
I too have put the stands where the lower control arm mounts (as per 2nd pic) with no issues.
This is by no means the correct way, but works fine for me.
Edited by Kane_R32
Don't use the rails as there really soft, even the sill which they recommend are to soft for stands.
My old 32 had completely demo'd sills and rails from previous owners jacking the car up incorrectly.
I think it also depends on the experience of the bloke using the jack.
At some time I've jacked all my cars from the chassis rails and haven't put a mark on them.
I use about 300mm of 100x10mm plate to spread the jack's point load plus timber between the plate and the chassis rail.
But whacking a jack straight onto a chassis rail will guarantee a dinted rail, they're simply not designed for that.
I had a Rustia so bad I couldn't open/shut doors once she was jacked, it didn't matter where you lifted that heap.
Calling them a chassis rail is even a stretch, one side stop halfway down the car FFS.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
