Os Giken 5 Speed Vs Ppg Straight Cut/helical Cut Dog Gears Vs Sequentials
After months and months of research, I've decided to go the OS88. Went for a drive in one and it was awesome. Quiet in gear, bit of clunking between gears but who cares about that, 4 choices of ratios and 6 speed. It also bolts straight into a R33 GTR so no shaft/transfer case changes.
It won't happen this year, but it'll happen. :)
We ended up with a Quaife/Trust 6 speed straight cut dog box, will be interesting to see how long it holds up.
My money is on the input shaft going first.....
GTRPSI: Be careful with the reverse gear on the Trust. It's only 18mm wide and the idler gear is smaller still. They have a tendency to not want to engage properly and the idler teeth are easily ground off if not engaged fully.
What shifter are you using on the Trust? How much power do you have?
Top choice, Piggaz. I'm in the same boat with the OS88 - it will happen eventually.
Straight cut is never an option. UNLESS, there is the top gear is helical. Freeway driving is important to a few guys in this thread.
How noisy is it. Can you take some videos?
New reverse gear has been fitted (guess why), and its a H pattern.
PT7175 on a 26/30 with E85, what power i plan to get and what i really get may be 2 different things, so no results to speak of yet as engine bottom end is going through assembly right now.
Just got it minus the transfer case, im going to rearrange the plates in our old transfer case (transfer case mod) and bolt it on, its been rebuilt, sitting near me right now waiting for the new engine to be finished.....
Spent yesterday gaping the rings, bottom end should be assembled next weekend when i find some time.
Not intended as a daily, more a 1/4 mile and Saturday night special, just put some ear plugs in if too loud. :)
Edited by GTRPSI
I was leaning towards a PPG straight cut dog box.. thoughts on that one?
A lot of people use them with what seems great success. That second gear is almighty tall though.
The BC Automotive GTR was using one.
GTRPSI, I would suggest you get a gear shift lever made up as the stock bush type one doesn't help reverse (the main reason they get damaged).
  • Like 1
Can you elaborate on the getting a gear shift lever made up?
I was unaware of that issue....
Thank your your wise words.
Will hunt for the clip later tonight. :)
  • 1 month later...
What are the options as far as straight cut dog boxes go?
I found a PAR dogbox for sale on ebay that was going pretty cheap, but apparently PAR's boxes are shit.
I hear Quaife/Trust are pretty good, but parts are hard to source.
And of course PPG, which are good but pricey.
Any other options out there?
I went out and spoke to Terry at Award A few months ago. He said there are two new options for us. Both are dog boxes and 6 speed I believe. That's all the info I have. It might be worth while giving him a call as he said he will have more info soon.
Apart from those two and what you have mentioned, I haven't found anything that stands out.
Found this on eBay, is that what they are worth?
http://www.ebay.com.au/itm/Nissan-R33-Gtr-Rb26-PPG-5-Speed-Straight-Cut-Dog-Box-/321456969727?pt=AU_Car_Parts_Accessories&hash=item4ad85417ff&_uhb=1
I am not putting out astronomical power (under 300kw) so other than advantage of quicker shifts I am having trouble seeing the value in spending over $8k on my gearbox. Yet, I still want one :ph34r:
I contacted Quafie and they put me onto the people who they made the boxes for, all parts are still avaliable, they also told me each part internally has a part number stamped on it, you just contact them with the part number, so to make it clear everything is still avaliable for the boxes and they also made it clear that they will continue to support parts for them.
Quaife Engineering made the boxes for Trust Japan originally. And yes, they have plenty of stock for all major parts.
Piggaz, Holinger and the OS88?
A copy of the email from the people who Quafie directed me for parts....i was chasing a bigger input shaft for ours for drag racing.
Hi Peter
I'm not sure I have much to tell you in a positive way, sorry !
We made that kit between 1992 and 2001, there were many changes made to it over the years, Here is a short answer to your questions ;
1. yes, we can still supply all the parts. The easiest way to quote, is to give me the part no. from the old item. Most of them start E3F1 and then two or three more digits, Numbers are stamped onto nearly everything apart from small parts and bearings
2. Bear in mind this kit fits into the stock casing This means gears are stock diameter. It also means ultimate power handling is restricted Probably to about 750 hp at the flywheel. We have a much newer much stronger sequential 6 speed far more capable of power in the 1000hp area. In my opinion, unless you have less than 750hp and dont mind a potential waiting time for spare parts then you are wasting your time with this kit. It was made so as to achieve 300kmph in time trials in Japan, not as a drag race or high strength kit. Anybody claiming to handle more than that power through stock diameter gears is talking BS. There is at least one manufacturer out your way claiming that !!
Hope I can help you further
kind regards
Website...
Though i might share some info from the horses mouth about the 6 speed H pattern Quaife/Trust Dog boxes. :)
Part of the reason I am looking at a dogbox is they are supposedly 'stronger' than a regular gearbox as they can take more power etc. but the more I hear about them the more temperamental they sound and it seems like the running costs don't get any less after the initial outlay.
After buying a dogbox, what sort of dollars are required to maintain it once it's in? Does it matter that I'm not running a lot of power?
I have used a ppg dogbox in a commodore cup around Wakefield and it was awesome, so I know the benefits when driving with one. It's just for $8k I could buy 8-9 regular gearboxes :P
    • Hello,new to the group, I bought a R32 from auction recently, wondering if anyone knows the cars history, seems to have the usual go fast bits on it, plan is to do an engine swap- add 2 extra cylinders and 1 extra turbo. https://www.dropbox.com/scl/fi/i4rjmlzubjbwjtguh6f4s/IMG20241011140744.jpg?rlkey=q0lumm251377vknbqktfwrycq&st=7scvwx4e&dl=0 https://www.dropbox.com/scl/fi/ro24qmwzlczzlfsr4y05x/Screenshot_2024-10-10-10-49-23-90_9a2f5bb2149dae94cd1e190effc09b33.jpg?rlkey=oyguh26ttshlf04ccp48odf4v&st=xloae97b&dl=0   New to forums and posting pics, if links don't work, take it easy on me, 42yrs old and I tune carburettors!!
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
